I am Cyrix james here and i am very new to Linux. I was looking for a lightweight Linux and came across Slax OS. its super fast and works smooth.i am trying to install bluetooth module to it .i install blueman it got installed but when iam trying to open it doesnt open.more over when i checked the bluetooth status its shows the follwing messages
Failed to obtain handles for “Service Changed” characteristic.
sap driver initialization failed.
Sap-server:Operation not permitted(1)
which Bluetooth module works with Slax Os.
Kindly guide me to install it and use it .
Did you look at the link I provided? It seems that Slax uses bluez module, not blueman. There is a download available from the link - if that doesn’t work, you can contact the developer directly.
I have no knowledge of Slax but it would appear to be very niche and it is uncertain as to how much support is available. If you still have issues, perhaps a move to a more popular lightweight distro would be advisable?
Hi Rich, the link you provided is headed by a notice saying Slax now uses ‘apt’, which I’m presuming means it’s debian based. If it’s debian based, then the “bluetooth” package should be a metapackage that includes bluez, bluez-tools and some other dependencies. “blueman” is a UI that talks to the bluez API, it’s not something I’ve used recently, but I can’t think of any reason why this wouldn’t work on Slax assuming that bluez can be made to work. There may be another UI you can use instead of blueman, but that combination should be Ok.
I totally agree it does look very niche, I too would recommend a more mainstream option, especially for new users …
