ok, now possibilities have been rised slightly
i now have 2 pcs to make one with
im gona post one now swap post other,
any body that could help shed some light on what i shoudl do would be cool
his pc, is ok but if i try run ââcrucial scanââ pc turns off (after format and before) seems to be a bit dippy in there somewhere
but i thaught maybe i can take ram,prossessor etc⌠but then⌠which board is best! lol
new pc from bro
SiSoftware Sandra
Computer
Model : AcerSystem Aspire 8000 XP DDRb
Workgroup : MSHOME
Host Name : porn-81b26f248f
User : deannn
Processor
Model : AMD Athlon⢠XP 2000+
Speed : 1.67GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Integrated Data Cache : 64kB, Synchronous, Write-Back, 2-way, 64 byte line size
L2 On-board Cache : 256kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size
Computer
Mainboard : KM266-8235
BIOS : Phoenix Technologies, LTD 6.00 PG 11/26/2002
Bus(es) : ISA X-Bus AGP PCI IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 1.22GB DDR
Chipset
Model : VIA VT8375 ProSavageDDR PM266/KM266 CPU to PCI Bridge
Front Side Bus Speed : 2x 133MHz (266MHz)
Total Memory : 1.25GB DDR
Shared Memory : 32MB
Memory Bus Speed : 2x 133MHz (266MHz)
Memory Module(s)
Memory Module : Samsung M3 68L6423BT1-CB0 256MB DDR PC2100U DDR-133 (2.5-3-3-6 2-0-0-0)
Memory Module : Team Group Team-Value-400 1GB DDR PC3200U DDR-200 (3-4-4-8 2-11-0-0)
Video System
Video Adapter : S3 Graphics ProSavageDDR (Microsoft Corporation) (AGP 2.00)
Peripherals
LPC Hub Controller 1 : VIA VT8235 PCI to ISA Bridge
LPC Legacy Controller 1 : Winbond W83697HF/F/HG
Audio Device : C-Media Electronics CMI8738/C3DX PCI Audio Device
Audio Codec : 1 0000h
Audio Codec : Gammagraphx 0000h
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Biostar Microtech VT82xxxx EIDE Controller (All VIA Chipsets)
USB Controller 1 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
USB Controller 2 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
USB Controller 3 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
USB Controller 4 : Biostar Microtech VT6202/12 USB 2.0 Enhanced Host Controller
SMBus/i2c Controller 1 : VIA VT823x SMBus
Network Services
Network Adapter : VIA Compatable Fast Ethernet Adapter - Packet Scheduler Miniport
Network Adapter : Realtek RTL8029(AS) PCI Ethernet Adapter - Packet Scheduler Miniport (Ethernet, 10Mbps)
Power Management
Mains (AC) Line Status : On-Line
