Over the past few days I’ve been messing around with themes from gnome-look.org and I couldn’t find one that was right or didn’t slow down the PC or in particular screw up Cairo Dock, but I found one that not only didn’t slow down the PC or screw up Cairo Dock but looked good as well which was Alba Cloud, I’m sure it’s not my imagination but my PC seems much snappier using this theme,
So I just wondering if anyone else has noticed a performance difference by changing to another theme or if anyone cares to try Alba Cloud just to see if it’s not my imagination
Well maybe it’s my imagination it’s not easy to do accurate comparison tests it’s just the feel of the machine seems faster and more fluent or maybe Cairo Dock just wasn’t to happy with any themes I used previously and I wasn’t aware of it
i thought certain themes would speed up your pc due to some using less shadowing effect or rendering to some heavy themes
with live wallpapers and so on ?? or am i thinking too much out of the box on this ?? :-X
I find that it all depends on the total Meg used and the # of steps needed to run the theme .
Simple is best and usually the theme that goes with the gui works best .
