dmesg | tail -n 40
[ 223.076267] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9823e80, 16000, 5
[ 223.076270] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9827d00, 16000, 5
[ 223.076273] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f982bb80, 16000, 5
[ 223.076277] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f982fa00, 16000, 5
[ 223.076280] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9833880, 16000, 5
[ 223.076283] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9837700, 16000, 5
[ 223.076286] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f983b580, 16000, 5
[ 223.076290] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f983f400, 16000, 5
[ 223.076293] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9843280, 16000, 5
[ 223.076297] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9847100, 16000, 4
[ 223.076300] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f984af80, 16000, 5
[ 223.076304] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f984ee00, 16000, 5
[ 223.076307] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9852c80, 16000, 5
[ 223.076311] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9856b00, 16000, 5
[ 223.076314] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f985a980, 16000, 5
[ 223.076317] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f985e800, 16000, 5
[ 223.076320] ndiswrapper (MmBuildMdlForNonPagedPool:1864): f9862680, 16000, 5
[ 223.098000] ndiswrapper (ndis_encode_setting:383): unknown type: 3
[ 223.399254] wlan0: ethernet device 20:4e:7f:e7:7c:8c using NDIS driver: bcmwlhigh5, version: 0x564442e, NDIS version: 0x501, vendor: ‘NDIS Network Adapter’, 0846:9011.F.conf
[ 223.405519] wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2-PSK; AES/CCMP with WPA, WPA2, WPA2-PSK
[ 223.492498] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 223.500492] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 223.509187] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 223.509837] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 244.475561] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1238.130598] usb 1-5: USB disconnect, device number 5
[ 1238.152513] ndiswrapper: device wlan0 removed
[ 1249.288027] usb 1-5: new high-speed USB device number 6 using ehci-pci
[ 1249.460215] usb 1-5: New USB device found, idVendor=148f, idProduct=2870
[ 1249.460225] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1249.580080] usb 1-5: reset high-speed USB device number 6 using ehci-pci
[ 1249.727566] phy1 → rt2800_init_eeprom: Error - Invalid RF chipset 0xffff detected.
[ 1249.727576] phy1 → rt2x00lib_probe_dev: Error - Failed to allocate device.
[ 1306.782337] usb 1-5: USB disconnect, device number 6
[ 1335.868042] usb 1-5: new high-speed USB device number 7 using ehci-pci
[ 1336.040294] usb 1-5: New USB device found, idVendor=148f, idProduct=2870
[ 1336.040303] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1336.160021] usb 1-5: reset high-speed USB device number 7 using ehci-pci
[ 1336.343514] phy2 → rt2800_init_eeprom: Error - Invalid RF chipset 0xffff detected.
[ 1336.343521] phy2 → rt2x00lib_probe_dev: Error - Failed to allocate device.
md5sum /lib/firmware/rt2870.bin
36c944c3138125605d28c0a3a1338be9 /lib/firmware/rt2870.bin
I get nothing back from rfkill list
