Compiz on peppermint
Hi Guys
I’ve just installed compiz, because I want to try the rotating cube thing everybody shouts about but mainly because I’m bored,
Anyway i installed compiz from synaptic but I see no reference to it in any of the menus but when I type"compiz" in the terminal I get this error message
graeme@Linux3 ~ $ compiz
compiz (core) - Error: Screen 0 on display ":0" already has a window manager; try using the --replace option to replace the current window manager.
graeme@Linux3 ~ $
None of this i understand
Can anyone please advise me on what i have to do next to get it working
It is telling you to replace your current windowmanager
Openbox is the default window manager for LXDE
gedit ~/.config/lxsession/LXDE/desktop.conf
If exists then replace
[Session]
window_manager=openbox-lxde
with
[Session]
window_manager=compiz ccp --indirect-rendering
Reboot to test.
Just a note that doing the above might disrupt other display related applications like compositing you may have already running.
Hi Sezo
thanks for your help
I’m glad you mentioned this because i was gonna ask about it
I installed compton to use with Cairo Dock so if you’re saying I could disrupt that and cause myself a headache I’d rather just leave compiz out, it’s really not that important to me, in other words I’m not that bored :slight_smile:
I am not saying that it would but that it could.
If you want to test it then just create another user so (if you mess it up) you dont ruin your main desktop.
The code posted before would only effect the current (that specific user).
I am using the LXDE enviroment for a reason - lightness. Compiz is a resource hog.
In my opinion if you want to use it then you might as well go with one of the heavier DEs. :wink:
I am using the LXDE enviroment for a reason - lightness. Compiz is a resource hog. In my opinion if you want to use it then you might as well go with one of the heavier DEs.
I’m inclined to take your advice on this, simply being a little bit bored is no good reason to risk spoiling a good working fast system, I suppose the rotating cube etc is quite an attractive proposition but having thought about it I dont think it’s worth the trade off (speed, resources etc)
Sorry if I’ve wasted your time
Many thanks
Sorry if I've wasted your time
Not at all. At one point i was taken in by the eye-candy but soon got bored wih it. Realizing that there is no added benefit (well other than bemused Windows users) I shifted towards more useful enviroments to get things done.
Makes perfect sense to me :slight_smile:
Thanks again
I’ve had a quick go at this, and Compiz doesn’t appear to like LXDE’s use of openbox … not xfwm4 (if I switch to that.
in both caases I loose Window decoration as soon as compiz starts … using compiz’s windows decorator makes no difference.
I suppose you could compile emerald for 12.04 … i’ve read that works inn Lubuntu, so should work in Peppermint.
But I’m with SeZo … Compiz is a gimmick … great for making Windows users go “Awwww” and “Ahhhh”, but it soon wears thin.
I can probably figure it out for you if you really want ? … other than the lost titlebars I’ve had it working, cube, wobbly windows, and all.
BTW, you’d want more than just the “compiz” package if you want to be able to configure compiz … you’ certainly want CCSM (compizconfig-settings-manager).
you’d probably want:-
compiz
compiz-plugins
compiz-fusion-plugins-extra
compiz-fusion-plugins-main
And life would be a lot easier with:
fusion-icon
as well … particularly if you need to switch between window managers because the effin window decorations are missing
Update:-
Compiz can be made to work in Peppermint 4
http://peppermintos.net/viewtopic.php?p=42113#p42113
Hi Mark
Thanks for your input,
between what I’ve learned from yourself and SeZo it seems it would be a lot of hard work for little or no benefit, possibly even counter productive
So I think this little whim of mine should go down as a classic case of “if it aint broken don’t fix it”
Many thanks
It does have a few handy features like Windows snapping (before Windows 7 did) and a compositor for transparency, drop shadows, etc.
But these can be achieved in different and much “lighter” ways … as SeZo says, Compiz can be a resource hog.
I have compton installed, which as you might remember I needed to get transparency for Cairo Dock, I also have drop shadows so I’m quite happy with that, I like eye candy but not really at the expense of performance, and I’m guessing that my PC probably isn’t up to it anyway
Many thanks
