(1) am I right thinking there’s a temperature sensor in the CPU
(2) were do I go to get weather info for the British Isles I’ve been referred to one website but it it’s American, the advise said you had to login and I can’t find a Registration or Login page
(3) what do you name the config file and were do you save it, do you need to set attributes/properties ? or reboot
For the cpu run:
sensors
sudo sensors-detect
This should give you some ideas as to what sensors are detected.
No idea (not using it)
(as glitch advised)
The config file .conkyrc is automatically created in your home folder at installation of conky.
Unfortunately you will have to edit it to suit your requirement by hand.
not really, though there is probably one on the motherboard for determining CPU temp … though you may have to install/configure lm-sensors to be able to read it
install lm-sensors:
sudo apt-get install lm-sensors
then configure them like SeZo suggests above.
{END EDIT]
Just for the record, if in future you wish to run more than one instance of Conky, then you can use:
conky -c ~/path/to/conkyrc/file &
I run about 3/4 different instances of Conky, you don’t have to use the one in your home directory you can download others from sites like DeviantArt where there is tons. Including ones for weather, which are much nicer than the HTC clock one IMO.
@Glitch - Like Mark says you needs to be fast as hell and on the ball around here. I compete with Mark (in my head) to beat him to the first reply… usually I lose. XD
@BKS - I didn’t know that about running multiple conkys. I just use the one which shows me everything I need to know.
You guys obviously just keep refreshing the forums every 2 seconds… don’t you people have lives! Haha I’m not as quick but it’s probably because I’m busy e-bombing the Pentagon… I mean… being a good boy!
Yeah, you can. I usually do it to function like Windows’ Rainmeter app, which I so badly which they’d port to Linux, but because of the way the desktop interacts with everything else, there’s like a layer the desktop sits on and it causes problems for Rainmeter.
I’m sure in time once they’ve figured out how to fix it, they’ll release it, but by then Conky will probably already have a GUI front-end for easy setting up, etc.
If I’m honest, my live is pretty much my laptop, LOL. The only time I need to go out is when I need alcohol… erm… grown up juice ( I don’t drink much >.< ) , and food.
I usually check the forums at least, 30/40 times a day. XD
Nah… Not a lot of programs. Old habit. Or maybe just because I can.
Used to have 3 or 4 separate instances of Conky and just liked them to pop up in a orderly fashion (delay timed)
I’ve found that if conky is in the startup list it messes up. I can’t remember the exact reason but by delaying it 10 secs or so it enables conky to work correctly.
