Converting video
I’m looking for a good video converter to convert any file format to another. I have lots of videos I want to convert so that my XboX can play them.
I have some ‘MPG’ and have tried ‘Arista’ but it failed to convert them (and it has other faults). Any other ‘good’ converters to recommend me?
avidemux maybe ? … though I’ve ever had ANY issues with Arista and the Xbox ???
Have you converted any 'MPG’s?
The ones I recently creates ‘cat’ wont convert to the XboX format!
I’m somewhat at a loss as to why you would want to rip them as MPEG2, then convert them in another application to Xvid … just use one of the ripping apps to rip and convert to Xvid in one go ???
or if you have problems ripping/coverting “on the fly” (as I sometimes do), rip the whole DVD to a folder with DVD decryptor, THEN use one of the ripping apps to rip/convert from that folder … they ALL can load a DVD from a folder.
Cos it’s all new to me …
AND my XboX wont play MPG format
ALso, what I am ripping is all mixed up…
Episode 1 runs into 2 1/2 VOB’s
11111111 VOB 1
11111111 VOB 2
11112222 VOB 3
22222222 VOB 4
I had to split them by chapter to be able to join them together properly.
Have you tried WinFF?
http://linuxforums.org.uk/general-help-advice/avcd-lite-and-linux-playereditor/msg68296/?topicseen#new
Never even heard of it, 'Ive used XP for ages. Don’t know much about Ubuntu/Linux.
I’ll take a look at it, hopefully it’s what I’m after.
OK, here’s how I did it … remember, you may be able to skip the ripping with DVD Decryptor, and rip directly from the DVD with k9copy … this works on one of my PC’s but not this one …
Put your DVD in the DVD drive.
Open DVD Decryptor, and go to Mode > ISO > Read … now select somewhere to save the ISO (such as your home directory) … and let DVD Decryptor rip the DVD to an ISO image.
Close DVD Decryptor.
install k9copy:
sudo apt-get install k9copy
Start k9copy assistant
On the “Source” screen, select ISO Image … and navigate to your ISO.
Click Next
On the “Destination” screen select Rip and encode DVD … and select a destination.
Click Next
On the “Select Title” screen, tick only the title you want
Click Next
On the “Select Streams” screen … leave the AC3 6ch audio ticked, but untick the English subtitles (looks like a little symbol) … unless you want to keep them).
Click Next
On the “Set MP4 options” screen …
Select the Video tab, and change to Codec: XviD
Select the Audio tab, and change to Codec: Mp3 (lame) … Bitrate: 256
Click Finish
Now wait whilst it rips and encodes the film.
Once finished … you can delete the ISO image you made with DVD Decryptor.
