deleting folder (SOLVED)
Hi Mark,
I recently installed BricsCAD and now want to delete it from my computer.
Is there a simple way ?
I have tried deleting folders but I still have an icon on the Graphics toolbar and I don’t feel as if the system is clear.
Can you help ?
take care
Don W
Open a terminal and post the output from:
dpkg -l | grep -i bric
This could be easily done in Synaptic, if you don’t fancy the terminal much :slight_smile:
Just search for it, right click, and “Mark for removal”, or “Mark for complete removal” if you need the disc drive space
Hi Mark,
I get this
don@ldwatson ~ $ dpkg -l | grep -i bric
ii bricscadv14 14.1.17 i386 BricsCAD is the number one DWG CAD alternative offering a complete and recognizable feature set to professional users. BricsCAD reads and writes the DWG format and offers high compatibility with AutoCAD®
don@ldwatson ~ $
Is this what you want ?
take care
Don W
Thanks chemicalfan, I didn’t think of that.
take care
Don W
Yeah, as there’s only one package, either “mark for complete removal” is Synaptic and “Apply” … or open a terminal and run:
sudo apt-get remove --purge bricscadv14
Hi Mark,
I have carried out your instructions and got this
don@ldwatson ~ $ sudo apt-get remove --purge bricscadv14
[sudo] password for don:
Reading package lists… Done
Building dependency tree
The following packages will be REMOVED
bricscadv14*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 139 MB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database … 176832 files and directories currently installed.)
Removing bricscadv14 …
Warning in file “/usr/share/applications/pcmanfm.desktop”: usage of MIME type “x-directory/normal” is discouraged (“x-directory” is an old media type that should be replaced with a modern equivalent)
Purging configuration files for bricscadv14 …
Processing triggers for gnome-icon-theme …
Processing triggers for shared-mime-info …
Unknown media type in type ‘all/all’
Unknown media type in type ‘all/allfiles’
Unknown media type in type ‘uri/mms’
Unknown media type in type ‘uri/mmst’
Unknown media type in type ‘uri/mmsu’
Unknown media type in type ‘uri/pnm’
Unknown media type in type ‘uri/rtspt’
Unknown media type in type ‘uri/rtspu’
Processing triggers for desktop-file-utils …
don@ldwatson ~ $
I found running the programme in 3d was a struggle as it said the computer did not support hardware needed to run 3d and it fell back to using software. Whatever, it was a pain trying to run it.
Thanks again
take care
Don W
Hi Mark,
When I started Pep4 up tonight, before the login screen appeared there was a blank screen and in the top left corner it said something like ‘looking for BricsCAD startup’ . Is this a problem I have created or can I ignore it ?
take care
Don W
run:
sudo updatedb
then post the output from:
locate brics
Hi Mark,
I have this
don@ldwatson ~ $ sudo updatedb
don@ldwatson ~ $ locate brics
/home/don/.local/share/Trash/files/.bricscad
/home/don/.local/share/Trash/files/bricscadv14.desktop
/home/don/.local/share/Trash/info/.bricscad.trashinfo
/home/don/.local/share/Trash/info/bricscadv14.desktop.trashinfo
don@ldwatson ~ $
take care
Don W
Those are just shortcuts I think, that you deleted manually maybe?
Can you post a screenshot of when the message comes up?
Dunno what that message was then … it all seems to be gone (except for those 2 items in your trash).
Thanks Mark,
The message has not reappeared, so it looks as though it’s gonefor good ;D
take care
Don W
PS I have emptied the trash
