I had a rack server kindly donated by a freind who had to move his data center recently. Im currently trrying to set it up on a virgin super hub.
The rack server has both up and down network port we have both ports direct in to the hub and both set on the same internal ip 192.168.0.100 manually.
one port network1 one prt network 2 in ubuntu.
In the HUB I have forwarded port 80 to this internal IP so that it can be used as a web server.
Both webmin and apache have been installed along with mysql and PHP 5.
I believe there are a few services on Virgin’s end that run on port 80, so that may conflict with they’re services.
Also, IIRC Virgin aren’t the nicest of chaps when it comes to running your own web server off of their “average joe” packages. Instead they look at someone who runs their own web server as a “business package consumer”, so you may receive a letter from them.
Just speaking from experience btw. I had Virgin some 10/11 months ago.
Also, if I were you, I wouldn’t use the Superhub for anything else than connecting you to the net. Ideally you’ll want to run your own router from the superhub in the so called “Modem mode”, that way you don’t get any of the failures that the superhub tends to be super at.
Like I say, you’ll be far better off running your own router with the Superhub in modem mode. It should be far easier to configure that way. Just be sure your own router can handle the 120MB speed.
but you can access it on the LAN ? … what I’m trying to find out is, is this an issue with port forwarding in the superhub ONLY
I’d still like to know what
ifconfig
returns
and if you can ping the server from the LAN
I’m going to assume the NIC just has 4 (or 2) active wires per port … but I’d assume the superhub isn’t smart enough to differentiate uplink/downlink … so is getting confused as to which port to send the data to.
I’d expect you’d need to do some routing in the router … but don’t know the superhub interface at all, and if it’s capable of that
it may be easier just to get a “normal” NIC … or as BkS suggests, find a router that does allow you to mess with the routing table and use the superhub as just a modem
