Over the last couple of days I’ve been experiencing a strange problem where the network will just randomly shut down and the network icon on the Panel disappears, I’ve always experienced the network dropping out now and again but it will normally reconnect after a minute or two , but this is different in as much as the only way I can reconnect is a reboot, once rebooted the connection is restored immediately and everything back to normal,
This has only started in the last few days after a kernel update, I’m not saying that has anything to do with it but it does seem a little coincidental
Assuming you are talking about wireless. It could be because of powering the adaptor down.
When this happens you could try to bring it up again (replace wlan0 to suit):
Ok it happened again so I went to open a text document I had SeZos command copied on from his last post and it wouldn’t open in fact no text document would open, so I’ll have to write it down and try again the next time it happens
