I tried to use Dropbox but was unsuccessful, now I would like to get rid of it. How do I get rid ?
Don W
Don W
what’s the output from:
dpkg -l | grep dropbox
ls -al ~/.config/autostart
Hi Mark,
don@ldwatson ~ $ dpkg -l | grep dropbox
ii nemo-dropbox 2.2.0-0~webupd8~xenial0 amd64 Dropbox integration for Nemo
don@ldwatson ~ $ ls -al ~/.config/autostart
If it’s not autostarting, why do you want to remove it ? … would you rather try fix it ?
But if you really want to remove it:
sudo apt-get remove --purge nemo-dropbox
Hi Mark,
I would rather keep it if it works.
I have downloaded the updated version but it says this when I try to run it :
ERROR: Breaks existing package ‘nemo-dropbox’ conflict: dropbox ()
How do I progress ??
Don W
What gets returned in the terminal if you run:
dropbox start -i
It shows the Dropbox start up box the same as what I get on startup.
EDIT When I try to login it says that dropbox is out of date. I have downloaded the latest version, dropbox_2015.10.28_amd64.deb
Run:
sudo dropbox update
and click the “OK” button.
Then try running dropbox from the menu
Thanks Mark,
There is an icon in the task bar that I can use to open Dropbox. It works very well.
Thanks again for your suggestions.
Don W
