Firefox 4
Firefox has just updated itself to version 4 But, there are a number of icons missing from the toolbar namely the ‘Home’ icon. Can anyone help?
Ubuntu 10.10 and 10.04
Right-click somewhere to the right of the tabs, when a drop down menu appears make sure “Navigation bar” is selected… the “Home” icon is now to the right of the search box.
You can select “Customise” from the same drop down menu, and add any icons that are available… whilst the customise window is open, you can also drag the home icon back to the left if you wish.
Hmm… If you stop the “Menu” bar being displayed, you’ve nearly got Chrome… Now if only I can find a way of getting rid of the window title bar…
:wink:
Yep, that works. :slight_smile:
