I noticed I have a folder on the bottom ‘taskbat’ and I don’t know how I put it there and I don’t know how to remove it. Any ideas?
Try to hold Alt while right-mouse clicking on the folder icon.
A menu should then appear giving you the options to either move it or remove from panel.
Nope, ‘Alt’ + Right Mouse click gives info on where it links to where it opens
Right Mouse click gives ‘Launch’ & ‘Properties’ and neither give options to remove it
Try …
Alt+Super+Right-click
Super = Windows logo key
That did the trick, thanks.
