BkS
October 9, 2011, 8:17pm
1
I use my HD tv as part of my dual-monitor set-up, and I used to be able to let the sound come through my TV’s speakers, as well as through the headphone socket for the laptop, giving me a nice somewhat surround sound system for my room (via Windoze). I’m not able to do this through Ubuntu, so some help or a step in the right path would be nice.
Outputs from
sudo lshw -C multimedia
*-multimedia
description: Audio device
product: 82801H (ICH8 Family) HD Audio Controller
vendor: Intel Corporation
physical id: 1b
bus info: pci@0000:00:1b.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0
resources: irq:48 memory:fc300000-fc303fff
sudo lshw -C display
*-display
product: G84 [GeForce 9500M GS]
vendor: nVidia Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:16 memory:c6000000-c6ffffff memory:d0000000-dfffffff memory:c4000000-c5ffffff ioport:2000(size=128)
asound -l
No command 'asound' found.
Can you post the output from:
aplay -l
Try this…
sudo apt-get install gnome-alsamixer
Then start GNOME ALSA Mixer , and put a tick in IEC958
Does audio work over HDMI now ?
BkS
October 10, 2011, 2:32am
3
Mark Greaves (PCNetSpec) post:2:
aplay -l
card 0: Intel [HDA Intel], device 0: ALC889 Analog [ALC889 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC889 Digital [ALC889 Digital]
Subdevices: 1/1
There was already a tick in IEC958. and also in IEC958 Default PCM
First of all I would have expected an audio playback device by nVidia to have been listed (but I could be wrong).
Have we ever edited your -
/etc/modprobe.d/alsa-base.conf
file to sort out an audio problem ?
Can you post the contents of that file:
gedit /etc/modprobe.d/alsa-base.conf
Which graphics drivers are you using, and how did you install them ?
BkS
October 11, 2011, 3:19am
5
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
install snd-pcm /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
install snd-mixer /sbin/modprobe --ignore-install snd-mixer $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-mixer-oss ; : ; }
install snd-seq /sbin/modprobe --ignore-install snd-seq $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; /sbin/modprobe --quiet --use-blacklist snd-seq-oss ; : ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; : ; }
# Cause optional modules to be loaded above sound card driver modules
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-emu10k1-synth ; }
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway)
install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist saa7134-alsa ; : ; }
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options saa7134-alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd-usb-audio index=-2
options snd-usb-caiaq index=-2
options snd-usb-ua101 index=-2
options snd-usb-us122l index=-2
options snd-usb-usx2y index=-2
# Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
# Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
# Keep snd-usb-audio from beeing loaded as first soundcard
I’m using the nVidia proprietary drivers, current version. I installed them via the “Additional Drivers”.
What was you laptop make model again ?
BkS
October 11, 2011, 12:17pm
7
Acer Aspire 6920 model number LF1
Is there nothing in the nVidia config application to do with HDMI audio that’s disabled/muted ?
Try adding a new line that reads -
options snd-hda-intel enable_msi=0 probe_mask=0xffff,0xfff2
to the bottom of /etc/modprobe.d/alsa-base.conf
gksudo gedit /etc/modprobe.d/alsa-base.conf
Then reboot and test HDMI audio
BkS
October 11, 2011, 1:30pm
9
Nope doesn’t work, but it also changed my theme to Ubuntu’s root one. ??? :o How weird.
If you run:
alsamixer
What’s listed when you hit F6
Also, still in alsamixer, does S/PDIF have 00 or MM above it ?
What else is listed across the bottom of alsamixer.
BkS
October 11, 2011, 2:15pm
11
Listed in alsamixer is:
- (default)
0 HDA Intel
1 USB Device 0x46d:0x9a4
enter device name...
S/PDIF has 00 in it. As does S/PDIF De .
Across the bottom of the alsamixer is:
http://farm7.static.flickr.com/6047/6234583108_3e6920f3b5_z.jpg
Click image for bigger photo.
Try adding yourself to the audio group.
BkS
October 11, 2011, 2:38pm
13
Nope, doesn’t make a difference.
