GRUB broken need help ASAP!!!!!!
30mins ago i upgraded Ubuntu from 10.10 to Natty (11.04). It asked me, what i wanted to do with GRUB and i selected ‘use local version currently installed’.
It then restarted and I got the following error message .
‘’ error: symbol not found : ‘grub_env_export’.
grub>rescue ‘’
really need to get grub fixed ASAP, i’m at a mates, so internet is available .
Boot to an 11.04 LiveCD (you will need an 11.04 LiveCD), then send me the output from:
or see here:
http://linuxforums.org.uk/ubuntu/reinstalling-grub-1-99-in-ubuntu-11-04-from-livecd-command-change/msg46911/#msg46911
Got the link to get a live CD
You can get the 11.04 LiveCD image from here… then burn it to CD, or USB
http://www.ubuntu.com/download/ubuntu/download
Be sure to get the correct architecture (32bit or 64bit) for the version you have installed.
Ok so the output:
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x222eb0b9
/dev/sda1 1 1698 13631488 27 Unknown
/dev/sda2 * 1698 16245 116854784 7 HPFS/NTFS
/dev/sda3 16245 29939 109994141 83 Linux
/dev/sda4 29939 30402 3715072 12 Compaq diagnostics
OK, boot to the 11.04 LiveCD… select “Try Ubuntu” (NOT “Install Ubuntu”) and when you’re at the desktop, open a terminal and enter:
sudo mount /dev/sda3 /mnt
sudo grub-install --boot-directory=/mnt/boot /dev/sda
Then REBOOT, to Ubuntu on the hard drive, open a terminal, and enter:
sudo update-grub
Next time you reboot, you should be offered both OS’s.
Once again! Thanks Mark! Oh btw, is there anyway I can move the launcher so it’s on the bottom? I don’t like it at the left hand side. Also can you use Emerald themes?
If you really want to go to the trouble of manually compiling Emerald… It looks like it can be made to work:
http://ubuntugenius.wordpress.com/2011/05/22/ubuntu-11-04-fix-enable-emerald-themes-for-compiz-fusion-window-borders-title-bars/
As for moving the launcher… NO, and according to Mark Shuttleworth there are no plans to make it movable.
https://bugs.launchpad.net/unity/+bug/668415/comments/2
Nothing stopping you logging on to the “classic” (GNOME 2) desktop though, and then (if you wish) using another dock bar.
I’m pretty sure I’ll just stick to the default themes I have then (: haha. I guess me and “Mr Shuttleworth” might be needing to have a few words. :wink:
I like the Unity desktop better! one of the reasons I upgraded :stuck_out_tongue: shame about the launcher though.
Just because Shuttleworth says it’s to remain on the left doesn’t mean some clever guy/gal won’t work out how to shift it… that’s the thing about open source :wink:
Same goes for third party themes etc.
Give em time… probably just a case of “Watch this space” :slight_smile:
Hehe, well I hope someone uses their nog and figures out how to move it :stuck_out_tongue: Oh mark, check your PM’s good sir!
