I would like to create a bootable usb stick for peppermintos 4, on a netbook running peppermintos 3.
in the past i have used creators on a windows computer, but now I’m windowless
thanks
Keith
thanks
Keith
Hi Keith
You can use unetbootin or usb-creator both are available in the repos.
Personally I prefer usb-creator-gtk it’s simple to use and just seems to work whereas unetbootin can sometimes be a bit unpredictable in my experience
Thanks Graeme,
I’ve opened the live usb creator and have downloaded the iso from the peppermint home page.
I now need advice on how to put the iso on the creator,I just can’t seem to do it.
Check this out it’s explains it better than I can
https://help.ubuntu.com/community/Installation/FromUSBStick
Thanks Graeme.
, I was doing something wrong, as soon as I realised, it went smoothly.
So now running this netbook on peppermint 4.
keith
That’s how we learn
Anyway glad you got it sorted out
Mark.
Your tutorial is as clear as day.
now I running this netbook on peppermint 4,
I tried to boot up my desktop with this usb stick but it will not boot up,
It was duel booted with peppermint 3 and xp,
when I tried to install peppermint 3 only, to get rid of xp, a few weeks ago, it part booted and would not go further, so now i have no idea whats wrong.
Any ideas?
thanks
Mark,
now I’ve installed peppermint 4, all I’ve done is get this site up and running,
can I follow the tutorial to installing peppermint 3 or will this conflict with peppermint 4?
If you’re on an AA1 (110/150) the instructions in the Peppermint 3 tutorial will work.
EXCEPT for stages 10 and 11 (fan control / Jupiter power manager) which will NOT work in Peppermint 4 and need differing instructions.
If you want further info, please start another topic … this one is titled “How do I create a bootable usb stick on a linux only netbook?” which from what I can see has been (SOLVED), and should be marked so
TIA
