Install player/stage/gazebo in ubuntu 12.04 LTS 64-bit systems
Hi Everyone,
you can visit the following link to install player/stage,it works for 64-bit 12.04 ubuntu systems
link:http://abhishekannamraju.blogspot.in/
link:http://abhishek4273.wordpress.com/
Have you tried to install player in ubuntu 14.04 LTS 64-bit system? I havent been able to do it. I have Stage running and Gazebo running.
I followed this instructions http://playerstage.sourceforge.net/doc/Player-cvs/player/install.html and installed this packages when possible and when not I used the most recent version for 14.04:
sudo apt-get install autotools-dev build-essential cmake cpp libboost-thread1.35.0 libboost-thread1.35-dev libboost-signals1.35.0 libboost-signals1.35-dev libcv1 libcv-dev libgdk-pixbuf2 libgdk-pixbuf-dev libgnomecanvas2-0 libgnomecanvas2-dev libgsl0 libgsl0-dev libjpeg62-dev libtool libxmu-dev swig freeglut3 freeglut3-dev libfltk1.1 libfltk1.1-dev libgtk2.0-dev libltdl7 libltdl7-dev libpng12-0 libpng12-0-dev
When I try to make it, thios is the error I get:
pepe@PPC:~/Player_Stage/src/player-3.0.2/build$ make
[ 1%] Built target playercommon
[ 1%] Generating functiontable_gen.h
[ 1%] Built target functiontable_gen
[ 1%] Generating interface_table.h
[ 1%] Built target interface_table
[ 1%] Generating player_interfaces.h
[ 2%] Built target player_interfaces
[ 4%] Built target playerinterface
[ 4%] Generating playerxdr.?
[ 4%] Built target playerxdr_src
[ 4%] Built target playerjpeg
Linking C shared library libplayerwkb.so
/usr/bin/ld: cannot find -lgeos
collect2: error: ld returned 1 exit status
make[2]: *** [libplayerwkb/libplayerwkb.so.3.0.2] Error 1
make[1]: *** [libplayerwkb/CMakeFiles/playerwkb.dir/all] Error 2
make: *** [all] Error 2
When I use make VERBOSE=1
cd /home/pepe/Player_Stage/src/player-3.0.2/build/libplayerwkb && /usr/bin/cmake -E cmake_link_script CMakeFiles/playerwkb.dir/link.txt --verbose=1
/usr/bin/cc -fPIC -Wall -shared -Wl,-soname,libplayerwkb.so.3.0 -o libplayerwkb.so.3.0.2 CMakeFiles/playerwkb.dir/playerwkb.o …/libplayercommon/libplayercommon.so.3.0.2 -lgeos -lgeos_c -Wl,-rpath,/usr/local/lib64
make[2]: Leaving directory /home/pepe/Player_Stage/src/player-3.0.2/build' make[1]: *** [libplayerwkb/CMakeFiles/playerwkb.dir/all] Error 2 make[1]: Leaving directory /home/pepe/Player_Stage/src/player-3.0.2/build’
any idea?
thanks
Try installing libgeos-dev
sudo apt-get install libgeos-dev
then recompiling
