This evening I’ve been trying to install bittorrentsync on my laptop running PM3 but it’s just not happening I downloaded the tar.gz from here http://labs.bittorrent.com/experiments/sync/other-download.html extracted the file and followed the instructions as per the website but nothing happens I tried both Linux x86 versions and neither of them work, both give this output when I try to install from the terminal
After you run that command did you try to access the WebUI
is the default way of accessing BitTorrent Sync. It can be reached at:
YourLocalIP:8888/gui
As instructed here.
