I have installed Windows 7 and Peppermint 5 on a Novatech computer. (The specs are in my signature).
I want to remove Win 7 and just use Peppermint. Where do I start with this ? I have a USB stick with Pep5 on it.
Don W
Don W
If you’ve only just installed Peppermint so haven’t customised it yet … by far the easiest way would just be to reinstall Peppermint, but this time tell it to use the entire hard drive
Choosing “Replace” at this screen:
http://linuxforums.org.uk/MGalleryItem.php?id=1595
should wipe the entire drive, then install Peppermint using the whole drive.
Thanks Mark,
I will do as you suggest.
Don W
Hi Mark,
Successfully completed thank you.
I will load the printer now.
Don W
I have loaded the printer successfully ;D
I have un-ticked the touchpad box and I can type this without letters being spread all over the place.
I guess I am too heavy handed at the keyboard
Don W
