I’m following the instructions for installing Peppermint Two onto my AA1.
So far, I’ve downloaded the Peppermint ISO and created a bootable USB, but when I try to fire up my AA1 from the USB, the screen opens on a black screen with the following white text at the top: SYSLINUX 4.04 EDD 2011-04-18 Copyright (c) 1994-2011.
My AA1 doesn’t progress past this message. Am I doing something wrong?
Using the check sum utility, I’ve confirmed the downloaded ISO file is OK, so I’ll try creating the bootable USB again in case something wasn’t quite right somewhere.
USB FDD is wrong … it should be listed as a USB HDD, so I doubt if the other LiveUSB creators will help, that’s more a function of the AA1’s BIOS seeing the USB stick as a USB floppy disk drive rather than USB hard disk drive.
You’ll probably need another USB stick … oddly enough the cheaper ones seem better for the AA1
Live mode will allow you to test drive without installing, but you won’t be able to save changes.
(Live mode acts like a CD)
Persistent mode, is the same as Live mode, but you WILL be able to save changes
(Persistent mode also acts like a CD, but can save changes, they will be saved to a “persistence” file on the USB stick)
Neither of those 2 will make changes to your SSD/HDD unless you tell it to.
Peppermint will NOT be as quick or as stable run from a LiveUSB as it would from the internal SSD/HDD, so don’t draw any speed or stability conclusions based on a LiveUSB test drive … but you CAN get a general feel for PeppermintOS.
I’ve installed Peppermint Two onto my AA1, thanks to the absolutely brilliant tutorial. It’s working perfectly - and really quickly! However, I’m not sure how to test the in-built camera. Could you point me in the right direction?
