just installed Linpus lite 1.9 on a dell insprion but cannot get it to wireless ,have followed the info in the linpus set up guide .tells you to go to the launch manager ,have looked for the search launch manager and cannot find it on the system or any where to download it Thanks
Hi tonys666, and welcome to the forum
Before we “try” to feel our way through Linpus … is there any particular reason you chose Linpus ?
You’ll find it hard going finding hep for that distro, as very few people use it … I’m not saying we can’t help, just that it will be harder work than if you chose a different distro.
Is there anything in the menus that refers to “Package Manager”, or Software Centre" etc ?
Can you say which model of inspiron … and whether you are using the built wireless, or a USB wireless adapter.
Looking at Quick Start Guide it would appear that they are using Gnome:
Launch manager is a quick and simple control panel for you to change your systems major settings. You can click the [b]launch manager icon in the top right corner of Gnome panel[/b] or launch via the function keys
for years have used Ubuntu on all pcs but need on the that will work on a touchscreen tryed many ubuntus ,other distro but unable to get the to touchscreen on my dell insprion all in one with touchcsreen .looked around tryed linpus and it work on the pc but no wireless pc as built in wireless .have looked in package manger etc
also looked in the launch manager on Gnome where there no notifcation of any thing to do with wireless connections but if i could get my ubuntu to touchscreen would use it.Thanks
OK, Linpus AFAIK is based on Fedora, let’s try to discover which wireless adapter you have …
What model of Inspiron ?
Can you open a terminal and send the output from these commands:
sudo lshw -C network
lspci -vnn | grep -i net
lsusb
[tonys666@localhost ~]$ sudo lshw -C network
*-network
description: Network controller
product: BCM4312 802.11b/g LP-PHY
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=b43-pci-bridge latency=0
resources: irq:17 memory:feafc000-feafffff
*-network
product: RTL8111/8168B PCI Express Gigabit Ethernet controller
physical id: 0
bus info: pci@0000:03:00.0
logical name: em1
version: 03
serial: 00:26:2d:1f:d8:36
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8168d-1.fw ip=192.168.0.11 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:43 ioport:e800(size=256) memory:fdfff000-fdffffff memory:fdff8000-fdffbfff memory:febe0000-febf
[tonys666@localhost ~]$ lspci -vnn | grep -i net
02:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 03)
[tonys666@localhost ~]$ lsusb
Bus 001 Device 003: ID 0c45:6310 Microdia Sonix USB 2.0 Camera
Bus 001 Device 006: ID 13fd:0840 Initio Corporation
Bus 002 Device 002: ID 1926:007a NextWindow 1950 HID Touchscreen
Bus 003 Device 002: ID 045e:00cb Microsoft Corp. Basic Optical Mouse v2.0
Bus 004 Device 002: ID 0566:3002 Monterey International Corp.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
OK, try this …
Make sure you’re PC is connected to your router by an ethernet cable and has an active internet connection whilst you run these commands
Open a terminal and run these commands in sequence
mkdir ~/wireless-driver
cd ~/wireless-driver
wget http://downloads.openwrt.org/sources/broadcom-wl-4.178.10.4.tar.bz2
tar xjf broadcom-wl-4.178.10.4.tar.bz2
cd ~/wireless-driver/broadcom-wl-4.178.10.4/linux
sudo b43-fwcutter -w /lib/firmware/ wl_apsta.o
sudo chmod 755 /lib/firmware/b43
sudo modprobe -r b43
sudo modprobe b43
Does your wireless spring to life ?
Check it still works after a reboot.
