Kodak ESP C310 and others in series
Does anyone know if any Linux distros have the drivers for this printer? I installed the drivers when my pc had win xp then changed to linux p4 and it worked but later after several more changes due to needing software that only worked on windows it seems tio have disappeared. Am back on linux peppermint 4 now.
Can you open a terminal (Ctrl+Alt+T) anr run this command:
dpkg -l | grep c2esp
then post the output back here.
yeah i entered
dpkg -l | grep c2esp pressed return and nothing happened
Install it:
sudo apt-get install c2esp
Are you able to add your printer now through the “Printers” GUI ?
well did it work sir?
