My laptop was just buzzing!!! I was on pic monkey editing some photos and my Maxtor HD stopped playing some music and there was this very loud buzzing!! So I rebooted. It is not buzzing now- what was that all about?!
Dunno … where was the buzzing coming from ? … speakers ?, fan ?, hard drive ?
Computers do that sometimes, maybe it took offense to the music you were playing
Try playing that piece by Rimsky-Korsakov and see if it plays in tune with the buzz ;D
OK I’ll get my coat…
Some of the stuff by Autechre sounds like a computer having a seizure!
Good one…
Depending on the type of buzz … computers definitely shouldn’t just “do that sometimes”…
Humming along to naff music is a human trait, usually triggered by Katie Parry.
Buzzing on the other hand tends to be associated more with Hawkwind :o
You weren’t listening to any Rimsky-Korsakov were you maybe like The Flight of The Bumble Bee
You are a witty lot LOL. I found out it only happens with the second movement of The Tempest sonata- obviously the file has gone funny. I will have to delete it from my Maxtor and download it again.
How old is the laptop?
Fans often wear, but more likely get a little clogged with dust … a spray from a pressurised air cleaner often works wonders … although there’s always a risk if you need to take any panels off to reach your fan(s).
Well it used to be a Windows XP one so that is quite old in computer terms. Yes, I thought it might need a clean- I will take it to the PC repair guy when I have the money- he could probably clean it safely.
I deleted The Tempest Sonata and downloaded it again- so far no more buzzing…
