Leaflet/brochure
What software can I get to create a leaflet? Looked in the software centre and couldn’t find any. I’m sure it’s there and i just cant find it … ! doesn’t have to be anything amazing just a simple leaflet/brochure
Any suggestions would be appreciated! =)
Try Scribus (desktop publishing) … it’s in Synaptic … it may be a good idea to also install the scribus-template and scribus-doc packages.
You can either install it/them through Synaptic, the Ubuntu Software Centre, or with this command:
sudo apt-get install scribus scribus-template scribus-doc
hth.
You may also find a template for OpenOffice which will work in LibreOffice here:
http://templates.services.openoffice.org/
or by searching the web for openoffice templates … or maybe scribus templates
Thanks =)
Also see the edit above :slight_smile:
ok thanks =) do not like making leaflets…!
Does anyone ? :wink:
Extra Scribus templates here:
http://scribusstuff.org/?xcontentmode=642
If you download one, you’ll need to unpack it, then start Scribus and go to File>Open … then point it at the .sla file that was contained in the downloaded template archive.
Got one =) cheers Mark! Fancy writing it ? =D
Heh … erm, not really :slight_smile:
Worth a try!
