further to my post ‘new ish laptop’ where Mark and chemicalfan helped me with my wifi, I had installed mint 16 cinnamon, with a view to upgrading to the LTS or installing Peppermint 5 LTS in a few months.
The problem I have is when I resume from suspend, sometimes the screen flickers and sometimes screen goes black, often after 5 mins or so. sometimes for a split second sometimes for 20 seconds or so.
The problem is erratic, sometimes there is no problem, but I’m rapidly losing faith.
I,ve been on the mint forum and it appears many have similar problems, I’ve looked for a solution, which there are loads of suggestions, but I don’t know which is correct for me.
I’ve done the sudo-suspend a few times and it seems to work ok.
I will have to try it over a longer period to see if it stops the problems.
on resuming from this command, I have to hit a key to bring the screen back on,
when I shut the lid without this command when resuming there is the blank screen with the curser and the screen comes on by itself.
@banko
Yeah for now that quirk will only be applied when you enter suspend with the above command … but once you’re sure it works, we’ll (hopefully) apply it system wide
@chemicalfan
I know what you mean … but discovering new stuff is the fun of Linux (at least for me)
(I learned something about “sudo” yesterday that should have been blatantly obvious [the -u option] … but hey, I know it now )
keith@keith-Lenovo-G550 ~ $ dpkg -l | grep acpi
ii acpi-support 0.142 i386 scripts for handling many ACPI events
ii acpid 1:2.0.18-1ubuntu2 i386 Advanced Configuration and Power Interface event daemon
