Logitec webcam and ubuntu 12.04
Hello,
I have a webcam that is for windows:
  1. Logitech quickcam v11.8
is it possible to use it on Ubuntu 12.04?
where can I find the drivers for ubuntu 12.04 ?
Thanks a lot for your support.
Blinky
Hi Blinky
I have a Logitec webcam not sure of the model but it’s the same as the attachment and it works for me I’m running Peppermint 4 which is an Ubuntu derivative so there’s no reason why it shouldn’t work for you.
I can’t speak for the Creative, personally I would just plug it in and see
Hello Emegra,
I tried to use it with skype and the creative doesn’t work.
I investigated around and found that the creative vista doesn’t work.
I really need some luck as some logitech work and some others don’t.
I will try again with the logitech …
Thanks.
Blinky
Hello,
all fixed.
I discovered that skype need having an external mic.
Thank you.
Blinky.
I didn’t really do much to help but you’re welcome
Glad you got it sorted
Does the webcam not have a built in mic ?
Open a terminal (Ctrl+Alt+T) and post the output from this command:
lsusb
arecord -l
