Loss of Sound
The sound on a desktop PC running Debian Jessie has stopped working - no
sound from any websites (e.g. BBC or YouTube) and trying to play a standard sound file I have saved which is
used to test the sound with vlc gives:
Audio output failed:
The audio device “default” could not be used:
Device or resource busy.
and in the terminal window it says:
VLC media player 2.2.6 Umbrella (revision 2.2.6-0-g1aae78981c)
[00000000013f0608] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000001318118] core libvlc: Running vlc with the default interface. Use ‘cvlc’ to use vlc without interface.
[00000000013f0608] alsa audio output error: cannot open ALSA device “default”: Device or resource busy
[00000000013f0608] core audio output error: module not functional
[00007fc2a8c02b08] core decoder error: failed to create audio output
Regards,
Mike
Try renaming your pulseaudio config directory, so it gets recreated on next boot.
I’m not au fait with how Debian implements pulseaudio, so can’t tell you exactly where that directory is located … but if you post the output from:
ls -a ~/ | grep pulse
ls -a ~/.config | grep pulse
I might be able to tell you
