Luminance HDR 2.4.0 for Linux
Does anyone know of a safe download for Luminance HDR 2.4.0 for Linux ?
The older version should be in the repos…
If you want the newer version, you could try compiling it yourself? Might be dependency issues though
You’ll need to be a bit more specific than “for Linux” :o
Sorry Mark.
Mint16 and Peppermint 4.
I assume there’s some new features in 2.4 that you want, and 2.3 isn’t good enough?
You’re either looking at compiling it yourself (might work, as long as all the dependencies are in order), or finding a PPA where the hard work has been done for you (potential security risk though, you’re trusting a stranger)
I’ll give 2.3 a go Chemicalfan. Thanks. :slight_smile:
Did you find it in the repos ok (Synaptic or Software Centre)?
Yes Chemicalfan. Thanks. :slight_smile:
I will try it out tomorrow.
Seems OK. Bit of a learning curve though. But I’ll persevere. :slight_smile:
