Micro sd card reading problems
Hello.
I have just purchased a 64gb micro Sandisk sdxc uhs-1 card. I cant get Peppermint 5 or Mint16 to recognise it properly. My Android phone won’t recognise it either.
Any suggestions.
Screen shot attached.
sudo apt-get install exfat-fuse exfat-utils
Now try inserting the card again
Thanks Mark.
It’s now showing it as a 29gb volume but then it says it has 63.8 gb space.
Do I have to partition it to two 32 gb volumes?
Dunno, does GParted ot “Disks” show any unpartitioned space ?
and what’s the output from:
Hi Mark.
First the out put;
Disk /dev/sda: 160.0 GB, 160000000000 bytes
255 heads, 63 sectors/track, 19452 cylinders, total 312500000 sectors
Disk identifier: 0x9106b803
/dev/sda1 * 2048 177145000 88571476+ 7 HPFS/NTFS/exFAT
/dev/sda2 177145854 312498175 67676161 5 Extended
/dev/sda5 177145856 308393983 65624064 83 Linux
/dev/sda6 308396032 312498175 2051072 82 Linux swap / Solaris
Disk /dev/sdb: 29.5 GB, 29504831488 bytes
255 heads, 63 sectors/track, 3587 cylinders, total 57626624 sectors
Disk identifier: 0x00000000
/dev/sdb1 32768 124735487 62351360 7 HPFS/NTFS/exFAT
Here is a screen shot of Gparted
I think it is more than likely that your devices cannot read the SDXC cards so they default to SDHC (4GB to 32GB). See here
Try a different card reader capable of reading SDXC cards.
I agree with SeZo … are you 100% sure your card reader is SDXC capable ?
Thought I do find it odd that fdisk sees
yet only uses
32768 → 124735487
Can you explain this statement:-
It's now showing it as a 29gb volume but then it says it has 63.8 gb space.
Where does it say that there’s 63.8GB of space ?
Yep SeZo is right. card reader problems.
Now shows the full 64gb.
Mark. With regard to the question of showing 63gb I was confusing it with another partition.
Thanks for the help Mark and SeZo. :slight_smile:
