Mint 15 won't dual boot
Hello everyone, just wondering if anyone has had a similar problem to me and knows a fix. I have tried several times to dual boot the Linux Mint 15 cinnamon 64.bit with my windows 7 ultimate with NO success. Is it down to my hardware set up and will the new Mint 16 have any better success, or should i use openSUSE instead for a better chance of success. My hardware set up is listed below, or is it something else i has missed.
I do realize it may be purely down to hardware issues, if so can any of the linux Os run on my rig in dual boot.
Any help would be greatly appreciated.
AMD 6 core 1055T OC’d to 3.8Ghz
GA 990XA-UD3 Skt M2
8.gig Dual Ch. ddr3 OC’d @ 1465
2.gig nVidia GT640
500.gig Seagate sataII HDD main drive
2Tb storage HDD
HD monitor @ 1842 x 1026 @ 50Hz
Hello imack, and welcome to the forum :slight_smile:
Can you describe the problem ?
Are you able to boot the LiveCD/LiveUSB to a working desktop, and it’s only after installation that it won’t boot ?
Can’t you boot the LiveCD/LiveUSB ?
How far does the boot get ? … are there any error messages displayed ?
Are you using a USB stick or CD/DVD as the installation media … if USB stick, how did you create the stick ? ← Important (as IIRC some Gigabyte mobo’s weren’t booting LiveUSB’s unless they were created in a very specific way.
What happens … does it just lock up … or does it reboot … do the keyboard lights start flashing ? … etc.
Hi Mark thanks for the reply, i am using the live cd, i can get as far as the stage before the menu with the install option that allow you to choose to install alongside windows or do a clean install etc, it just sits there prior to that section and does nothing, i even left it for 30.mins just sat there doing nothing, after 6 attempts of it stopping at the same stage i gave up at that point.
I did run it from the live cd without trying to install and it will run, but i have colour degrade booting from the cd only on my HD monitor, everything is a light green blue with a washed out effect if that helps in any way.
Is it getting stuck on this page?
http://static.howtoforge.com/images/perfect_desktop_mint_15_cinnamon_64bit/big/4.jpg
If so make sure that the system have at least 6.1 GB available drive space and should be connected to the Internet.
It might be worth to see the status of your HDD partitions before you attempt the install next time.
When booted to the desktop from the Live CD open the Terminal (press Ctrl+Alt+T on your keyboard to open terminal)
and run (that is lower case L):
and post it back
Do what SeZo suggests so we can have a look at how it’s currently partitioned.
okay will do thanks.
Just done as you requested, this is the results.
mint@mint ~ $ sudo fdisk -l
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0xa4fe0630
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 976766975 488280064 7 HPFS/NTFS/exFAT
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sdb’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0x6f326672
/dev/sdb1 1985 1953519615 976758815+ f W95 Ext’d (LBA)
Partition 1 does not start on physical sector boundary.
/dev/sdb5 2048 1471883263 735940608 7 HPFS/NTFS/exFAT
/dev/sdb6 1471885312 1580165119 54139904 7 HPFS/NTFS/exFAT
/dev/sdb7 1580167168 1953519615 186676224 7 HPFS/NTFS/exFAT
mint@mint ~ $
Where are you planning on putting Linux …
on the 500GB drive (dual booting with Windows
Can you also boot to the liveCD again and run:
parted /dev/sdb
then when you’re at a “(parted):” prompt run:
print
then:
quit
then post the output from the “print” command
I have a feeling the GPT partitioned drive is giving the installer problems … is it an internal or external HDD ?
Hi its an internal 500.gig, my main ‘C’ drive, i was going to put linux on the same drive, it has no partitions on it and over 200.g free, i will run the codes you asked.
is the 2TB drive internal or external ?
The 2TB is internal as well, i imputed the code parted /dev/sdb and it said i was not a superuser and to watch out for my permissions and on the next line it said 'no such directory or file found.
It would not let me proceed past that stage.
Would the new mint 16 have any better luck on the dual boot or do you think it would encounter the same problems.
Also
The screen just stops no error messages, no reboot, it just stops, keyboard lights flash up okay and i am on average 12 to 14.mb dsl/lan and no problems running the live cd, except for a very pink screen instead of the proper green background.
OK if a command ever tells you you need to be “super user” … prefix that command with “sudo”, as in
sudo parted /dev/sdb
I meant when it locks up, do the keyboard lights start flashing on and off ?
I don’t knw if Mint 16 would get any further … I suspect not … but only one way to be sure.
Have you tried disconnecting the 2TB drive during the installation … then reconnecting it once installed ?
You might as well use Mint 16, as support for Mint 15 ends in 6 weeks…
heh … yeah, there is that :slight_smile:
Okiay tried the dual boot withg mint 16, it stopped on code line CR6, then went in with live cd and ran the code requested, here is the result.
mint@mint ~ $ sudo parted /dev/sdb
GNU Parted 2.3
Using /dev/sdb
Welcome to GNU Parted! Type ‘help’ to view a list of commands.
(parted) print
Model: ATA ST1000DM003-9YN1 (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Number Start End Size Type File system Flags
1 1016kB 1000GB 1000GB extended lba
5 1049kB 754GB 754GB logical ntfs
6 754GB 809GB 55.4GB logical ntfs
7 809GB 1000GB 191GB logical ntfs
(parted) quit
mint@mint ~ $
Next i will try disconnecting my 2TB to see if that makes a difference.
Sorry my error, it’s a 1TB internal not a 2TB, that one is in my external.
Weird…
Can you post a screenshot of the failure somehow? Maybe take a picture with a camera-phone or something, if PrtScn doesn’t work?
Are you sure it wasn’t a CRC error, not CR6 ?
I still think it’s the 1TB internal HDD that’s confusing the installer (though it shouldn’t).
When booted to the LiveCD/LiveUSB, are you able to access the 1TB drives contents ?
If so, try shutting down and disconnecting it … then try installing … you can always reconnect it after installation.
