system
1
Something I have been thinking about for a while.
Downloaded ISOs are in a home folder.
I normally use Unetbootin to transfer to USB Flash which works very well.
Is it possible to put more than one live O/S on to a flash drive and boot independently.
Purely for interest.
Jocklad
system
3
Thanks chemicalfan will have a good look at that.
Jocklad
system
5
Thanks Guys,
Will have a go at this in slow time.
Jocklad
system
6
Was alright till I got to the Terminal.
What is the command to open it.
Jocklad
To run what ? … the install script, or MultiSystem after installing ?
system
8
When you double click the desktop Icon and execute in Terminal you get:
ben@ben-Dell-DV051 ~/Desktop $
Jocklad.
If the install script is on your desktop, run:
~/Desktop/install-depot-multisystem.sh
system
10
Thanks Mark its now installed.
Jocklad
system
12
Not happy with this program.
Peppermint 5 freezing.
Have removed it.
Jocklad
