Hi all,
I am trying to install a alfa AWUS036NHVhttp://www.alfa.com.tw/products_show.php?pc=34&ps=201 on ubuntu but im running into some errors. And i think its driver issues.
the only thing is i know nothing about how drivers work on unix and am trying to learn at the same time of fixing this issue.
There was also a post that was for the 8188eu driver but not the 8188eus http://linuxforums.org.uk/index.php?topic=11261.msg95851#msg95851
So let me give some details.
the chipset is RTL8188EUS and i think the driver that is installed is RTL8188EU
I am runing 3.13.0 generic on vmworkstation.
I can see networks but not there signal strength
And i get the fallowing results from these commands
iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lsusb
Bus 001 Device 002: ID 0bda:8179 Realtek Semiconductor Corp.
Bus 002 Device 004: ID 0e0f:0008 VMware, Inc.
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
airmon-ng
Interface Chipset Driver
Thanks for any help
0bda:8179 should be covered by the r8188eu driver.
sudo lshw -C network
sudo iwlist scanning
Is there a list of these somewhere? Across the common drivers as well? Or is it just a case of Googling those ID numbers?
eth0 Interface doesn't support scanning.
lo Interface doesn't support scanning.
wlan0 Scan completed :
Cell 01 - Address: 08:86:3B:76:61:7C
ESSID:"belkin.17c"
Protocol:IEEE 802.11bgn
Mode:Master
Frequency:2.412 GHz (Channel 1)
Encryption key:on
Bit Rates:144 Mb/s
Extra:wpa_ie =dd160050f20101000050f20401000050f20401000050f202
IE: WPA Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
Extra:rsn_ie =30140100000fac040100000fac040100000fac020000
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
IE: Unknown: DDBA0050F204104A00011010440001021057000101103B00010310470010BC329E001DD811B2860108863B76617C1021001442656C6B696E20496E7465726E6174696F6E616C1023001D42656C6B696E204E373530444220576972656C65737320526F757465721024000746394B313130331042000E31323334353647383930313233341054000800060050F20400011011001D42656C6B696E204E373530444220576972656C65737320526F75746572100800020084103C000101
Cell 02 - Address: BC:85:56:3C:4E:52
ESSID:"HP-Print-52-LaserJet 400 color"
Mode:Master
Frequency:2.437 GHz (Channel 6)
Encryption key:off
Bit Rates:54 Mb/s
Cell 03 - Address: 20:4E:7F:1E:6C:A4
ESSID:"RB53288"
Mode:Master
Encryption key:on
Bit Rates:108 Mb/s
Extra:wpa_ie =dd1c0050f20101000050f20202000050f2040050f20201000050f2020c00
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Extra:rsn_ie =30180100000fac020200000fac04000fac020100000fac020c00
Group Cipher : TKIP
IE: Unknown: DD7F0050F204104A00011010440001021041000100103B000103104700106FE7B0D8713E6D40911A130B0E94047F1021000D4E4554474541522C20496E632E10230009574E5231303030763310240009574E523130303076331042000538333235381054000800060050F204000110110009574E52313030307633100800020084
Cell 04 - Address: 48:F8:B3:0B:66:98
ESSID:"Cisco17531"
Mode:Master
Frequency:2.462 GHz (Channel 11)
Encryption key:off
Bit Rates:108 Mb/s
IE: Unknown: DD740050F204104A0001101044000101103B00010310470010E37C8ACE1035919037DDD3C5CAE71CCA102100074C696E6B73797310230004453830301024000776312E302E30301042000234321054000800060050F20400011011000445383030100800022688103C0001011049000600372A000120
*-network
product: 82545EM Gigabit Ethernet Controller (Copper)
vendor: Intel Corporation
physical id: 1
bus info: pci@0000:02:01.0
logical name: eth0
version: 01
serial: 00:0c:29:dc:6a:5d
capacity: 1Gbit/s
width: 64 bits
clock: 66MHz
capabilities: pm pcix bus_master cap_list rom ethernet physical logical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000 driverversion=7.3.21-k8-NAPI duplex=full ip=192.168.2.19 latency=0 link=yes mingnt=255 multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:19 memory:fd5c0000-fd5dffff memory:fdff0000-fdffffff ioport:2000(size=64) memory:e7b00000-e7b0ffff
*-network
physical id: 2
bus info: usb@1:1
logical name: wlan0
serial: 00:c0:ca:85:07:1a
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=r8188eu multicast=yes wireless=unassociated
Try this … with a cabled connection to your router, open a terminal and run these commands in sequence:-
sudo apt-get install build-essential linux-headers-generic dkms
mkdir ~/8188EU
cd ~/8188EU
wget https://github.com/lwfinger/rtl8188eu/archive/master.zip
unzip master.zip
cd ~/8188EU/rtl8188eu-master
make
sudo make install
sudo modprobe -r r8188eu
sudo modprobe 8188eu
Did wireless spring to life ? … if so, we may need to blacklist the r8188eu driver.
Sad to say nothing changed. still can see wifi but cant see there stangths and cant been picked up by airmon as well
So im guessing it has to be the other driver
lsmod
What other driver ?
Try this:
sudo modprobe -r 8188eu
sudo modprobe 8188eu rtw_power_mgnt=0 rtw_enusbss=0
how is wireless now.
any errors from those, post them here.
slarosa
November 4, 2014, 10:27pm
8
Ok so there are two drivers the eu and eus my chipset is eus
you wanted the lsmod
Module Size Used by
cfg80211 484040 0
hid_generic 12548 0
crct10dif_pclmul 14289 0
crc32_pclmul 13113 0
ghash_clmulni_intel 13216 0
aesni_intel 55624 0
aes_x86_64 17131 1 aesni_intel
lrw 13286 1 aesni_intel
gf128mul 14951 1 lrw
glue_helper 13990 1 aesni_intel
vmw_balloon 13415 0
ablk_helper 13597 1 aesni_intel
cryptd 20359 3 ghash_clmulni_intel,aesni_intel,ablk_helper
snd_ens1371 25427 2
snd_ac97_codec 130285 1 snd_ens1371
ac97_bus 12730 1 snd_ac97_codec
gameport 15758 1 snd_ens1371
snd_pcm 102099 2 snd_ac97_codec,snd_ens1371
serio_raw 13462 0
snd_page_alloc 18710 1 snd_pcm
snd_seq_midi 13324 0
snd_seq_midi_event 14899 1 snd_seq_midi
snd_rawmidi 30144 2 snd_ens1371,snd_seq_midi
snd_seq 61560 2 snd_seq_midi_event,snd_seq_midi
r8188eu 814658 0
snd_seq_device 14497 3 snd_seq,snd_rawmidi,snd_seq_midi
vmwgfx 175358 3
snd_timer 29482 2 snd_pcm,snd_seq
usbhid 52659 0
hid 106148 2 hid_generic,usbhid
ttm 85150 1 vmwgfx
btusb 32412 0
snd 69322 12 snd_ac97_codec,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_ens1371,snd_seq_device,snd_seq_midi
rfcomm 69160 8
bnep 19624 2
bluetooth 391136 22 bnep,btusb,rfcomm
soundcore 12680 1 snd
drm 303102 4 ttm,vmwgfx
vmw_vmci 62966 0
i2c_piix4 22155 0
shpchp 37032 0
parport_pc 32701 1
mac_hid 13205 0
ppdev 17671 0
lp 17759 0
parport 42348 3 lp,ppdev,parport_pc
psmouse 106714 0
mptspi 22542 2
mptscsih 40150 1 mptspi
ahci 25819 0
libahci 32716 1 ahci
e1000 145174 0
mptbase 101822 2 mptspi,mptscsih
vmw_pvscsi 22858 0
vmxnet3 49693 0
floppy 69418 0
I am still vary limited as i was at the start. This alfa is supposed to be able to be put into monitoring mode and other things. If you look at the script alfa has in the “linux” driver download it ascks if you have the eu or the eus and there script is not working for kali or for ubuntu. have not tried it on fedora yet.
slarosa
November 4, 2014, 10:30pm
9
Did you try what I said in my last posting ?
slarosa
November 4, 2014, 11:16pm
11
yep still at the same point.
slarosa
November 5, 2014, 12:17am
13
filename: /lib/modules/3.13.0-39-generic/kernel/drivers/net/wireless/8188eu.ko
version: v4.1.4_6773.20130222
author: Realtek Semiconductor Corp.
description: Realtek Wireless Lan Driver
license: GPL
srcversion: A64F36E917C62797F04AD4E
alias: usb:v056Ep4008d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3311d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3310d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p330Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0DF6p0076d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v07B8p8179d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp0179d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp8179d*dc*dsc*dp*ic*isc*ip*in*
depends:
vermagic: 3.13.0-39-generic SMP mod_unload modversions
parm: rtw_ips_mode:The default IPS mode (int)
parm: ifname:The default name to allocate for first interface (charp)
parm: if2name:The default name to allocate for second interface (charp)
parm: rtw_initmac:charp
parm: rtw_channel_plan:int
parm: rtw_chip_version:int
parm: rtw_rfintfs:int
parm: rtw_lbkmode:int
parm: rtw_network_mode:int
parm: rtw_channel:int
parm: rtw_mp_mode:int
parm: rtw_wmm_enable:int
parm: rtw_vrtl_carrier_sense:int
parm: rtw_vcs_type:int
parm: rtw_busy_thresh:int
parm: rtw_ht_enable:int
parm: rtw_cbw40_enable:int
parm: rtw_ampdu_enable:int
parm: rtw_rx_stbc:int
parm: rtw_ampdu_amsdu:int
parm: rtw_lowrate_two_xmit:int
parm: rtw_rf_config:int
parm: rtw_power_mgnt:int
parm: rtw_smart_ps:int
parm: rtw_low_power:int
parm: rtw_wifi_spec:int
parm: rtw_antdiv_cfg:int
parm: rtw_antdiv_type:int
parm: rtw_enusbss:int
parm: rtw_hwpdn_mode:int
parm: rtw_hwpwrp_detect:int
parm: rtw_hw_wps_pbc:int
parm: rtw_max_roaming_times:The max roaming times to try (uint)
parm: rtw_fw_iol:FW IOL (int)
parm: rtw_mc2u_disable:int
parm: rtw_80211d:Enable 802.11d mechanism (int)
parm: rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm: debug:Set debug level (1-9) (default 1) (int)
