I’ve just up graded to 11.10 how do I view and edit the installing log I got several errors not empty directory and a warning at one point’
It’s also very slow as another member said but I expected that
I’ve got ubuntu 11.10
athlon 2650e
83.6 disk space
But AFAIK, for an “Upgrade” there should be a log file at:- /var/log/dist-upgrade/main.log
but I could be wrong … on the whole, I usually do fresh installs … so I’ve never looked for a dist-upgrade log, and currently don’t have a system that would contain one.
Ehh ??? … YOU marked the topic as “Fixed” yesterday (but have now apparently removed the “Fixed” tag) … and you didn’t respond to my questions … so now I’m REALLY confused.
You tell us … is it fixed ?
Don’t change the topic title to “Fixed” or “Solved” until you consider it fixed or solved.
