New sound card white noise only
This is the output from one of the commands I’ve just though is this because I haven’t changed the BIOS (I don’t know how to do that) or is it normal when you have integrated and card sound
*-multimedia
description: Audio device
product: 82801H (ICH8 Family) HD Audio Controller
vendor: Intel Corporation
physical id: 1b
bus info: pci@0000:00:1b.0
version: 02
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:48 memory:50420000-50423fff
*-multimedia
description: Multimedia audio controller
product: CM8738
vendor: C-Media Electronics Inc
physical id: 1
bus info: pci@0000:06:01.0
version: 10
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_cmipci latency=32 maxlatency=24 mingnt=2
resources: irq:22 ioport:1000(size=256)
gordon@gordon-desktop:~$
Can I ask why you added the second card ?
the on-board sound stopped working and I’m trying to do online courses so I need sound, some computer advise come in video form but I can’t get to it
You’ll have to disable the onboard sound card in the BIOS … does your PC display a message similar to:-
F2 = Setup
Del = System Setup
F12 = BIOS
as soon as you turn on your PC ?
yes f2
Well hit F2 when you see that message then … that will take you into the BIOS settings … look for an option to disable the onboard sound card … disable it … then SAVE and Exit.
Then boot to Linux, and send the output from:
sudo lshw -C multimedia
gordon@gordon-desktop:~$ sudo lshw -C multimedia
[sudo] password for gordon:
*-multimedia
physical id: 1b
version: 02
width: 64 bits
clock: 33MHz
*-multimedia
product: CM8738
physical id: 1
version: 10
width: 32 bits
clock: 33MHz
That still appears to be finding BOTH sound cards … are you SURE you disable the onboard soundcard in the BIOS, and SAVED the changes ?
no I haven’t I don’t know how to ?
That’s not something I can talk you through … I don’t have access to your BIOS interface … all I can say is what I said in my last posting
When yu turn on your PC, and see a message Similar to:
F2 = System Settings
Hit F2 … that will take you into the BIOS settings … look for an option to enable/disable the onboard sound card … disable it … then SAVE and Exit.
OK, we could probably bang an ~/.asoundrc file together, and blacklist the snd_hda_intel driver, but disabling the onboard soundcard would definitely be the better option.
I’m going to guess the C-Media CM8738 is the add-in (new) card ?
aplay -l
gordon@gordon-desktop:~$ aplay -l
card 0: Intel [HDA Intel], device 0: STAC92xx Analog [STAC92xx Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: STAC92xx Digital [STAC92xx Digital]
Subdevices: 1/1
card 1: CMI8738 [C-Media CMI8738], device 0: CMI8738 [C-Media PCI DAC/ADC]
Subdevices: 1/1
card 1: CMI8738 [C-Media CMI8738], device 1: CMI8738 [C-Media PCI 2nd DAC]
Subdevices: 1/1
card 1: CMI8738 [C-Media CMI8738], device 2: CMI8738 [C-Media PCI IEC958]
Subdevices: 1/1
I’ll have a look for that
It would STILL be best to disable the onboard soundcard in the BIOS … but if you CAN’T do that …
WARNING - What follows is NOT necessary if you’ve disabled the onboard soundcard in the BIOS … so ONLY do this if you HAVEN’T disabled the onboard sound … if you apply this with only one sound card, it will probably stop sound working altogether.
Try this … Open a terminal and run:
gedit ~/.asoundrc
When gedit opens an EMPTY file, make it read:-
pcm.!default {
type hw
card 1
ctl.!default {
type hw
card 1
SAVE the file … and REBOOT to test.
The audio setting in the BIOS is set to disabled it’s in the peripheral group, …I did’nt action your last post as per instructions
Did you JUST change the BIOS setting … or was it ALREADY disabled ?
aplay -l
now ?
*-multimedia
product: CM8738
physical id: 1
version: 10
width: 32 bits
clock: 33MHz
card 0: CMI8738 [C-Media CMI8738], device 0: CMI8738 [C-Media PCI DAC/ADC]
Subdevices: 1/1
card 0: CMI8738 [C-Media CMI8738], device 1: CMI8738 [C-Media PCI 2nd DAC]
Subdevices: 1/1
card 0: CMI8738 [C-Media CMI8738], device 2: CMI8738 [C-Media PCI IEC958]
Subdevices: 1/1
still no sound I’ve rebooted as well
could this be resposoniable
sudo gedit /etc/modprobe.d/alsa-base.conf
and remove the 5 lines at the end that read -
options snd-hda-intel model=ref
so the last 2 lines now read -
Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-2
SAVE the file … and exit gedit.
I doubt it, but what are the bottom few lines of that file ?
Can you boot to a LiveCD/LiveUSB and check if sound works ?
yes it will boot to a live CD
he is the last lines
Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
you can comment out that last line if you wish, so it now reads
But it’s not necessary.
does sound WORK from a LiveCD ?
I did delete the last line but there is still no sound, sorry I read your comment wrong but there’s no sound from the DVD
