Hi Guys
I’ve just installed Peppermint 4 on a PC for the missus and i made kinda hard work of it because I installed without an internet connection, I finally got everything working and up to date (or at least I think I have), the only problem i’m left with is i can,t get flash to work, I’ve checked in synaptic and it’s saying it’s installed, under Chromium plugins Adobe flash player version 11.2 r202 is listed and enabled, but when I try to run any you tube video I’m told shockwave flash could not load, when I try to install flash-plugin from the terminal I get this output
pat@Linux4 ~ $ sudo apt-get install flash-plugin
[sudo] password for pat:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package flash-plugin
pat@Linux4 ~ $ sudo apt-get install flashplugin
Package flashplugin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
flashplugin-installer
E: Package 'flashplugin' has no installation candidate
pat@Linux4 ~ $
graeme
