Is there a limit as to how many tabs I can have open re opening them for devices as mine keep ‘crashing’ after opening 7 in 1 window.
tabs for devices ??
tabs in what ?
If you mean in the nautilus file manager … there was an issue with nautilus crashing in 11.10 which I assumed was fixed but could be wrong.
The fix was to (if present) delete ~/.nautilus with:
rm -rf ~/.nautilus
and completely uninstall the nautilus-open-terminal plugin with:
sudo apt-get remove --purge nautilus-open-terminal
If you absolutely MUST have the “Open Terminal Here” option … there is supposed to be a workaround using a script rather than the nautilus plugin here:
http://www.cyberciti.biz/faq/linux-gnome-open-terminal-shell-prompt-here/
Don’t ask me how well this works though
Another known issue that only seemed to apply to the Gnome (Classic) desktop in 11.10 was that nautilus sometimes crashed because of the Ubuntu One client … so if you don’t use Ubuntu One, you can uninstall the client with:
sudo apt-get remove ubuntuone-client-gnome
Sorry, I meant these tabs;
http://img822.imageshack.us/img822/4983/tabsd.th.jpg
I’ll uninstall Ubuntu One as I don’t use it, ta.
