system
March 29, 2013, 9:40pm
1
I’m not sure if this should be on the official Openshot forum but I thought I would try here first if that’s ok
Recently I’ve been trying out Openshot, I started by trying to make a film clip consisting of still Images of my Grand-daughter to music and trying various transitions etc.
Anyway to start with Openshot couldn’t be considered fast and crashing wasn’t exactly infrequent but it was useable but as the project has grown it’s became almost unusable, at the moment the project consists of approximately 60 still images, 3 songs and a few transitions lasting 11 minutes, I don’t have a particularly powerful PC (2gb ram & a 1.6 ghz dual core processor) so I didn’t expect it to be greased lightening but I did expect it to be usable. as it is now it takes almost 6 minutes just to open the project, and trying to edit anything can take a similar time
“top” shows cpu usage for openshot ranging from 11% to 105% (dont know how it works that out) and memory usage fairly light at around 33% and according to a sysinfo screenlet it appears to be using both cores.
It could well be that my PC just isn’t up to it, but I watched a you tube video tutorial where the guy demonstrated it on a laptop with a single core processor running Linux ( he expressed the point that it would be a bit slow because of this) and it was way faster than mine.
Any suggestions or advice would be much appreciated
I know sod all about video editing.
Which version of openshot are you running, and in which distro/version ?
Latest (stable) is 1.4.3 … from this PPA:
https://launchpad.net/~openshot.developers/+archive/ppa
If this is to be a simple slideshow with music for a DVD … have you looked at imagination
http://www.my-guides.net/en/guides/linux-dvd-video/how-to-create-a-photo-dvd-slideshow-in-linux
Homepage:
http://imagination.sourceforge.net/
but BE AWARE … it’s available in your package manager, so don’t download it from sourceforge.
system
March 29, 2013, 10:26pm
3
Hi Mark
I started with v 1.4.0 which i installed from synaptic, when I started having the serious problems I completely uninstalled and then installed the latest version (v1.4.3) from the official PPA, but it hasn’t made any noticeable difference, in fact the first attempt to edit crashed the program, the problem could be the way I’ve compiled the video but I suppose the only answer to that would be to start the project over again and I’ve put quite a lot of work into it.
It’s not really a big deal I am getting by the way it is, I just wondered if it could be a problem with my PC or some setting I can change or package I could install, that would help
Many thanks
system
March 29, 2013, 10:31pm
4
If this is to be a simple slideshow with music for a DVD .. have you looked at imagination
I’ve never heard of Imagination but i can have a look.
I chose Openshot because I wanted to try to learn video editing, I just started with a photo slideshow, but ultimately i want to get a bit more ambitious with some video I have that I shot myself and try to use various effects etc
SeZo
March 29, 2013, 10:51pm
5
I have used Openshot last year for a while but found that it did have an issue with the MLT libraries it used.
Although my problem was general slowness but not as bad as yours (on a single core and 1gb memory).
Eventually moved over onto Kdenlive and never looked back.
Also tried Lives that worked ok.
Something else to considere, does it haveto transcode the clips you are using? That would slow it down too.
system
March 29, 2013, 11:02pm
6
Hi SeZo
Thanks for your help
I thought about Kdenlive ( I’ve read quite a lot of good things about it) but I didn’t want all the the KDE libraries that would install with it, i did download cinelerra but that looked a bit complicated for me and from what I read was prone to crashing as well, I don’t know anything about Lives, but I’m open to suggestions, basically i want something that’s fairly easy to learn but with enough features to get more ambitious and challenging as i learn more
To be honest i don’t know, the image files are al jpegs, and the sound files are all mp3s
Many thanks
system
March 29, 2013, 11:06pm
7
A thought has just occurred to me (dont laugh)
Could my problem be that all the files I’m using are on my network server, and it’s the network that’s slowing things down ?
SeZo
March 29, 2013, 11:17pm
8
Could my problem be that all the files I'm using are on my network server, and it's the network that's lowing things down ?
I doubt it would cause too much of a problem but if you try it with local files and it is better then all is good.
As for Kdenlive bringing in lots of kde libraries, I did not notice any but maybe they were already installed (as I do use some KDE stuff like K3B etc).
You could try Lives, I found it OK but just preferred Kdenlive.
FYI … here’s a simulated install of kdenlive in Peppermint … as you can see there’s a TON of dependencies …
mark@AA1-Blue ~ $ sudo apt-get install --simulate kdenlive
Reading package lists… Done
Building dependency tree
The following extra packages will be installed:
docbook-xsl dvdauthor dvgrab gstreamer0.10-alsa icoutils kate-data katepart
kde-runtime kde-runtime-data kdelibs-bin kdelibs5-data kdelibs5-plugins
kdenlive-data kdoctools kubuntu-debug-installer libattica0.3
libcanberra-pulse libclucene0ldbl libdlrestrictions1 libkatepartinterfaces4
libkcmutils4 libkde3support4 libkdeclarative5 libkdecore5 libkdesu5
libkdeui5 libkdewebkit5 libkdnssd4 libkemoticons4 libkfile4 libkhtml5
libkidletime4 libkio5 libkjsapi4 libkjsembed4 libkmediaplayer4
libknewstuff3-4 libknotifyconfig4 libkntlm4 libkparts4 libkpty4
libkrosscore4 libktexteditor4 libmlt++3 libmlt-data libmlt4 libnepomuk4
libnepomukdatamanagement4 libnepomukquery4a libnepomuksync4 libnepomukutils4
libntrack-qt4-1 libntrack0 libphonon4 libplasma3 libpolkit-qt-1-1
libqapt-runtime libqapt1 libqca2 libqjson0 libqt4-opengl libqt4-qt3support
libsolid4 libsoprano4 libsox-fmt-alsa libsox-fmt-base libsox1b libssh-4
libstreamanalyzer0 libstreams0 libthreadweaver4 libvirtodbc0 melt
ntrack-module-libnl-0 odbcinst odbcinst1debian2 oxygen-icon-theme phonon
phonon-backend-gstreamer plasma-scriptengine-javascript qapt-batch
recordmydesktop shared-desktop-ontologies soprano-daemon virtuoso-minimal
virtuoso-opensource-6.1-bin virtuoso-opensource-6.1-common
Suggested packages:
docbook-xsl-doc-html docbook-xsl-doc-pdf docbook-xsl-doc-text
docbook-xsl-doc libsaxon-java libxalan2-java libxslthl-java
docbook-xsl-saxon fop xalan dbtoepub libterm-readline-gnu-perl
libterm-readline-perl-perl djvulibre-bin finger hspell
libqca2-plugin-cyrus-sasl libqca2-plugin-gnupg libqca2-plugin-ossl
libsox-fmt-all phonon-backend-vlc phonon-backend-xine phonon-backend-mplayer
The following NEW packages will be installed
kdenlive kdenlive-data kdoctools kubuntu-debug-installer libattica0.3
0 upgraded, 88 newly installed, 0 to remove and 16 not upgraded.
Inst libphonon4 (4:4.7.0really4.6.0-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst libqjson0 (0.7.1-6 Ubuntu:12.04/precise [i386])
Inst libqt4-opengl (4:4.8.1-0ubuntu4.4 Ubuntu:12.04/precise-updates [i386])
Inst libqt4-qt3support (4:4.8.1-0ubuntu4.4 Ubuntu:12.04/precise-updates [i386])
Inst libssh-4 (0.5.2-1ubuntu0.12.04.2 Ubuntu:12.04/precise-updates [i386])
Inst odbcinst (2.2.14p2-5ubuntu3 Ubuntu:12.04/precise [i386])
Inst odbcinst1debian2 (2.2.14p2-5ubuntu3 Ubuntu:12.04/precise [i386])
Inst gstreamer0.10-alsa (0.10.36-1ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst phonon-backend-gstreamer (4:4.7.0really4.6.2-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst docbook-xsl (1.76.1+dfsg-1ubuntu1 Ubuntu:12.04/precise [all])
Inst dvdauthor (0.7.0-1.1build1 Ubuntu:12.04/precise [i386])
Inst icoutils (0.29.1-2 Ubuntu:12.04/precise [i386])
Inst kate-data (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Inst libdlrestrictions1 (0.14.2ubuntu5 Ubuntu:12.04/precise [i386])
Inst libkdecore5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libattica0.3 (0.3.0-0ubuntu2 Ubuntu:12.04/precise [i386])
Inst libkdeui5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkcmutils4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libclucene0ldbl (0.9.21b-2 Ubuntu:12.04/precise [i386])
Inst virtuoso-opensource-6.1-common (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst libvirtodbc0 (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst soprano-daemon (2.7.5+dfsg.1-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst libsoprano4 (2.7.5+dfsg.1-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst libnepomuk4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libsolid4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libstreams0 (0.7.7-1.1ubuntu3 Ubuntu:12.04/precise [i386])
Inst libstreamanalyzer0 (0.7.7-1.1ubuntu3 Ubuntu:12.04/precise [i386])
Inst libkio5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libnepomukquery4a (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libnepomukutils4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkparts4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libktexteditor4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkatepartinterfaces4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst katepart (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkdeclarative5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkpty4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkdesu5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkdewebkit5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkdnssd4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkemoticons4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkfile4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkjsapi4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkhtml5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkidletime4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkmediaplayer4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libknewstuff3-4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libknotifyconfig4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libnepomukdatamanagement4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libnepomuksync4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst ntrack-module-libnl-0 (016-1ubuntu1 Ubuntu:12.04/precise [i386])
Inst libntrack0 (016-1ubuntu1 Ubuntu:12.04/precise [i386])
Inst libntrack-qt4-1 (016-1ubuntu1 Ubuntu:12.04/precise [i386])
Inst libqca2 (2.0.3-2 Ubuntu:12.04/precise [i386])
Inst libthreadweaver4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libplasma3 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst phonon (4:4.7.0really4.6.0-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst kde-runtime-data (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Inst libkde3support4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkjsembed4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkntlm4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libkrosscore4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libpolkit-qt-1-1 (0.103.0-1 Ubuntu:12.04/precise [i386])
Inst kdelibs5-data (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Inst kdoctools (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst kdelibs-bin (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst kdelibs5-plugins (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst oxygen-icon-theme (4:4.8.3-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Inst shared-desktop-ontologies (0.8.1-1 Ubuntu:12.04/precise [all])
Inst plasma-scriptengine-javascript (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst kde-runtime (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Inst libsox1b (14.3.2-3 Ubuntu:12.04/precise [i386])
Inst libmlt4 (0.7.6+git20120204-2 Ubuntu:12.04/precise [i386])
Inst libmlt++3 (0.7.6+git20120204-2 Ubuntu:12.04/precise [i386])
Inst kdenlive-data (0.8.2.1-1ubuntu1 Ubuntu:12.04/precise [all])
Inst libmlt-data (0.7.6+git20120204-2 Ubuntu:12.04/precise [all])
Inst melt (0.7.6+git20120204-2 Ubuntu:12.04/precise [i386])
Inst kdenlive (0.8.2.1-1ubuntu1 Ubuntu:12.04/precise [i386])
Inst libqapt1 (1.3.1-0ubuntu2 Ubuntu:12.04/precise [i386])
Inst libqapt-runtime (1.3.1-0ubuntu2 Ubuntu:12.04/precise [i386])
Inst qapt-batch (1.3.1-0ubuntu2 Ubuntu:12.04/precise [i386])
Inst kubuntu-debug-installer (11.10ubuntu1 Ubuntu:12.04/precise [i386])
Inst libcanberra-pulse (0.28-3ubuntu3 Ubuntu:12.04/precise [i386])
Inst libsox-fmt-alsa (14.3.2-3 Ubuntu:12.04/precise [i386])
Inst libsox-fmt-base (14.3.2-3 Ubuntu:12.04/precise [i386])
Inst recordmydesktop (0.3.8.1+svn602-1ubuntu3 Ubuntu:12.04/precise [i386])
Inst virtuoso-opensource-6.1-bin (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [i386])
Inst virtuoso-minimal (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [all])
Inst dvgrab (3.5-2 Ubuntu:12.04/precise [i386])
Conf libphonon4 (4:4.7.0really4.6.0-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf libqjson0 (0.7.1-6 Ubuntu:12.04/precise [i386])
Conf libqt4-opengl (4:4.8.1-0ubuntu4.4 Ubuntu:12.04/precise-updates [i386])
Conf libqt4-qt3support (4:4.8.1-0ubuntu4.4 Ubuntu:12.04/precise-updates [i386])
Conf libssh-4 (0.5.2-1ubuntu0.12.04.2 Ubuntu:12.04/precise-updates [i386])
Conf odbcinst (2.2.14p2-5ubuntu3 Ubuntu:12.04/precise [i386])
Conf odbcinst1debian2 (2.2.14p2-5ubuntu3 Ubuntu:12.04/precise [i386])
Conf gstreamer0.10-alsa (0.10.36-1ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf phonon-backend-gstreamer (4:4.7.0really4.6.2-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf docbook-xsl (1.76.1+dfsg-1ubuntu1 Ubuntu:12.04/precise [all])
Conf dvdauthor (0.7.0-1.1build1 Ubuntu:12.04/precise [i386])
Conf icoutils (0.29.1-2 Ubuntu:12.04/precise [i386])
Conf kate-data (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Conf libdlrestrictions1 (0.14.2ubuntu5 Ubuntu:12.04/precise [i386])
Conf libkdecore5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libattica0.3 (0.3.0-0ubuntu2 Ubuntu:12.04/precise [i386])
Conf libkdeui5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkcmutils4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libclucene0ldbl (0.9.21b-2 Ubuntu:12.04/precise [i386])
Conf virtuoso-opensource-6.1-common (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf libvirtodbc0 (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf soprano-daemon (2.7.5+dfsg.1-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf libsoprano4 (2.7.5+dfsg.1-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf libnepomuk4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libsolid4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libstreams0 (0.7.7-1.1ubuntu3 Ubuntu:12.04/precise [i386])
Conf libstreamanalyzer0 (0.7.7-1.1ubuntu3 Ubuntu:12.04/precise [i386])
Conf libkio5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libnepomukquery4a (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libnepomukutils4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkparts4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libktexteditor4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkatepartinterfaces4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf katepart (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkdeclarative5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkpty4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkdesu5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkdewebkit5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkdnssd4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkemoticons4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkfile4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkjsapi4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkhtml5 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkidletime4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkmediaplayer4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libknewstuff3-4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libknotifyconfig4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libnepomukdatamanagement4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libnepomuksync4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf ntrack-module-libnl-0 (016-1ubuntu1 Ubuntu:12.04/precise [i386])
Conf libntrack0 (016-1ubuntu1 Ubuntu:12.04/precise [i386])
Conf libntrack-qt4-1 (016-1ubuntu1 Ubuntu:12.04/precise [i386])
Conf libqca2 (2.0.3-2 Ubuntu:12.04/precise [i386])
Conf libthreadweaver4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libplasma3 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf phonon (4:4.7.0really4.6.0-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf kde-runtime-data (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Conf libkde3support4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkjsembed4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkntlm4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libkrosscore4 (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libpolkit-qt-1-1 (0.103.0-1 Ubuntu:12.04/precise [i386])
Conf kdelibs5-data (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Conf kdoctools (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf kdelibs-bin (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf kdelibs5-plugins (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf oxygen-icon-theme (4:4.8.3-0ubuntu0.1 Ubuntu:12.04/precise-updates [all])
Conf shared-desktop-ontologies (0.8.1-1 Ubuntu:12.04/precise [all])
Conf plasma-scriptengine-javascript (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf kde-runtime (4:4.8.5-0ubuntu0.1 Ubuntu:12.04/precise-updates [i386])
Conf libsox1b (14.3.2-3 Ubuntu:12.04/precise [i386])
Conf libmlt4 (0.7.6+git20120204-2 Ubuntu:12.04/precise [i386])
Conf libmlt++3 (0.7.6+git20120204-2 Ubuntu:12.04/precise [i386])
Conf kdenlive-data (0.8.2.1-1ubuntu1 Ubuntu:12.04/precise [all])
Conf libmlt-data (0.7.6+git20120204-2 Ubuntu:12.04/precise [all])
Conf melt (0.7.6+git20120204-2 Ubuntu:12.04/precise [i386])
Conf kdenlive (0.8.2.1-1ubuntu1 Ubuntu:12.04/precise [i386])
Conf libqapt1 (1.3.1-0ubuntu2 Ubuntu:12.04/precise [i386])
Conf libqapt-runtime (1.3.1-0ubuntu2 Ubuntu:12.04/precise [i386])
Conf qapt-batch (1.3.1-0ubuntu2 Ubuntu:12.04/precise [i386])
Conf kubuntu-debug-installer (11.10ubuntu1 Ubuntu:12.04/precise [i386])
Conf libcanberra-pulse (0.28-3ubuntu3 Ubuntu:12.04/precise [i386])
Conf libsox-fmt-alsa (14.3.2-3 Ubuntu:12.04/precise [i386])
Conf libsox-fmt-base (14.3.2-3 Ubuntu:12.04/precise [i386])
Conf recordmydesktop (0.3.8.1+svn602-1ubuntu3 Ubuntu:12.04/precise [i386])
Conf virtuoso-opensource-6.1-bin (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [i386])
Conf virtuoso-minimal (6.1.4+dfsg1-0ubuntu1 Ubuntu:12.04/precise [all])
Conf dvgrab (3.5-2 Ubuntu:12.04/precise [i386])
mark@AA1-Blue ~ $
system
March 29, 2013, 11:29pm
10
Thinking back, on one occasion while using Openshot my server crashed (kernel panic) and up to that point the server hasn’t had one second downtime in 6 months, so I think I’ll try moving the files to a local location and trying that, it will probably mean a lot of work but if nothing else it should tell me if that’s the problem or not.
I’m reluctant at this point to try another program because In spite of the problems I’m having I like Openshot and also switching to another application would likely mean starting completely from scratch as Lives or kdenlive is unlikely to work with an existing Openshot project.
Many thanks
system
March 29, 2013, 11:30pm
11
FYI .. here's a simulated install of kdenlive in Peppermint .. as you can see there's a TON of dependencies ..
that’s why I avoided Kdenlive
Did you read my posting about the public beta of Lightworks being due out soon:
http://linuxforums.org.uk/index.php?topic=10767.0
That’s probably going to be what you want … a professional grade video editor.
system
March 29, 2013, 11:46pm
13
That's probably going to be what you want .. a professional grade video editor.
I’ve heard about Lightworks and it looks amazing but I just want to do simple video editing at least to begin with and openshot looks like it has everything I need if only i can get it to work better, maybe one day I will need a professional grade video editor like that but Lightworks costs money, are you forgetting I’m a Scotsman ?
I think after trying having the files stored locally this is one of those cases where you may get more assistance on the software’s own forum.
But if you do get a working solution from openshot … can you post what it was
system
March 30, 2013, 12:03am
16
From what I gather there's a free and a paid version.
You’re right again, I’ll have a look at that.
But out of curiosity do you think my problem could be that I’m streaming the files from my network, because if it is then any editor I use will likely have the same issues will it not ?
system
March 30, 2013, 12:05am
17
But if you do get a working solution from openshot .. can you post what it was
Yes I will. I’m definitely gonna try moving the files to a local directory and I’ll post the results here
Once again thanks for your help
Goodnight
system
March 31, 2013, 1:29pm
18
Ok I tried moving all the files to a local directory and the difference is like night & day Openshot is much much faster & fluid, loading a project now only takes seconds whereas it took minutes before and general editing although sometimes a little slow doesn’t freeze up for 5 or 6 minutes before becoming usable again, there is still occasional crashing but that might just be the nature of the program or maybe my PC isn’t quite powerful enough to use this program flawlessly, but at least it reloads quickly so I can live with that, so all in all it looks like importing files in Openshot from a network location is not to be recommended
Many thanks to Mark & SeZo for your help
Happy to hear you got to the root of the problem
Dunno what you’re thanking me for though ???
