[code Boot Info Script 0.60 from 17 May 2011
============================= Boot Info Summary: ===============================
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos1)/boot/grub on this drive.
sda1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Peppermint
Boot files: /boot/grub/menu.lst /boot/grub/grub.cfg /etc/fstab
/boot/grub/core.img
sda2: __________________________________________________________________________
File system: Extended Partition
Boot sector type: -
Boot sector info:
sda5: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 20.0 GB, 20003880960 bytes
255 heads, 63 sectors/track, 2432 cylinders, total 39070080 sectors
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 * 2,048 38,021,119 38,019,072 83 Linux
/dev/sda2 38,023,166 39,069,695 1,046,530 5 Extended
/dev/sda5 38,023,168 39,069,695 1,046,528 82 Linux swap / Solaris
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 a47d0f4b-fb86-4143-a047-98241b5186c7 ext4
/dev/sda5 77fc397d-6a1f-46f1-9d74-71d7bee82472 swap
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda1 / ext4 (rw,errors=remount-ro,commit=0)
=========================== sda1/boot/grub/menu.lst: ===========================
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-legacy-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 3
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=a47d0f4b-fb86-4143-a047-98241b5186c7
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## specify if running in Xen domU or have grub detect automatically
## update-grub will ignore non-xen kernels when running in domU and vice versa
## e.g. indomU=detect
## indomU=true
## indomU=false
# indomU=detect
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Peppermint Two, kernel 2.6.38-11-generic
uuid a47d0f4b-fb86-4143-a047-98241b5186c7
kernel /boot/vmlinuz-2.6.38-11-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro quiet splash
initrd /boot/initrd.img-2.6.38-11-generic
title Peppermint Two, kernel 2.6.38-11-generic (recovery mode)
kernel /boot/vmlinuz-2.6.38-11-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro single
title Peppermint Two, kernel 2.6.38-8-generic
kernel /boot/vmlinuz-2.6.38-8-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro quiet splash
initrd /boot/initrd.img-2.6.38-8-generic
title Peppermint Two, kernel 2.6.38-8-generic (recovery mode)
kernel /boot/vmlinuz-2.6.38-8-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro single
title Chainload into GRUB 2
root a47d0f4b-fb86-4143-a047-98241b5186c7
kernel /boot/grub/core.img
title Peppermint Two, memtest86+
kernel /boot/memtest86+.bin
### END DEBIAN AUTOMAGIC KERNELS LIST
=========================== sda1/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="1"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(/dev/sda,msdos1)'
search --no-floppy --fs-uuid --set=root a47d0f4b-fb86-4143-a047-98241b5186c7
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=800x600
load_video
insmod gfxterm
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=en_US
insmod gettext
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ "$linux_gfx_mode" != "text" ]; then load_video; fi
menuentry 'Peppermint, with Linux 2.6.38-11-generic' --class peppermint --class gnu-linux --class gnu --class os {
recordfail
set gfxpayload=$linux_gfx_mode
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-2.6.38-11-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro quiet splash vt.handoff=7
menuentry 'Peppermint, with Linux 2.6.38-11-generic (recovery mode)' --class peppermint --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
echo 'Loading Linux 2.6.38-11-generic ...'
linux /boot/vmlinuz-2.6.38-11-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro single
echo 'Loading initial ramdisk ...'
submenu "Previous Linux versions" {
menuentry 'Peppermint, with Linux 2.6.38-8-generic' --class peppermint --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-2.6.38-8-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro quiet splash vt.handoff=7
menuentry 'Peppermint, with Linux 2.6.38-8-generic (recovery mode)' --class peppermint --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
echo 'Loading Linux 2.6.38-8-generic ...'
linux /boot/vmlinuz-2.6.38-8-generic root=UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
if [ "x${timeout}" != "x-1" ]; then
if keystatus; then
if keystatus --shift; then
set timeout=-1
else
set timeout=0
fi
else
if sleep --interruptible 3 ; then
set timeout=0
fi
fi
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda1/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid -o value -s UUID' to print the universally unique identifier
# for a device; this may be used with UUID= as a more robust way to name
# devices that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=a47d0f4b-fb86-4143-a047-98241b5186c7 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda5 during installation
UUID=77fc397d-6a1f-46f1-9d74-71d7bee82472 none swap sw 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
=================== sda1: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
8.260013580 = 8.869122048 boot/grub/core.img 1
12.278491974 = 13.183930368 boot/grub/grub.cfg 1
12.497253418 = 13.418823680 boot/grub/menu.lst 1
2.045509338 = 2.196348928 boot/initrd.img-2.6.38-11-generic 3
4.336914062 = 4.656726016 boot/initrd.img-2.6.38-8-generic 2
1.930664062 = 2.073034752 boot/vmlinuz-2.6.38-11-generic 2
8.258285522 = 8.867266560 boot/vmlinuz-2.6.38-8-generic 1
2.045509338 = 2.196348928 initrd.img 3
4.336914062 = 4.656726016 initrd.img.old 2
1.930664062 = 2.073034752 vmlinuz 2
8.258285522 = 8.867266560 vmlinuz.old 1
=============================== StdErr Messages: ===============================
unlzma: Decoder error
