/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda1 during installation
UUID=20b8bb11-b91f-4f4c-97ab-8e8389ce785d / ext4 errors=remount-ro 0 1
swap was on /dev/sda5 during installation
UUID=17bc2c9d-2fa3-4758-9ca1-afd5c767d2de none swap sw 0 0
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ “${next_entry}” ] ; then
set default=“${next_entry}”
set next_entry=
save_env next_entry
set boot_once=true
else
set default=“0”
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option=“–id”
else
menuentry_id_option=“”
fi
export menuentry_id_option
if [ “${prev_saved_entry}” ]; then
set saved_entry=“${prev_saved_entry}”
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z “${boot_once}” ]; then
saved_entry=“${chosen}”
fi
function recordfail {
set recordfail=1
if [ -n “${have_grubenv}” ]; then if [ -z “${boot_once}” ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root=‘hd0,msdos1’
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 20b8bb11-b91f-4f4c-97ab-8e8389ce785d
else
search --no-floppy --fs-uuid --set=root 20b8bb11-b91f-4f4c-97ab-8e8389ce785d
fi
font=“/usr/share/grub/unicode.pf2”
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_GB
insmod gettext
fi
terminal_output gfxterm
if [ “${recordfail}” = 1 ] ; then
set timeout=-1
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=10
Fallback normal timeout code in case the timeout_style feature is
unavailable.
else
set timeout=10
fi
fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/06_mint_theme
set menu_color_highlight=white/light-gray
END /etc/grub.d/06_mint_theme
BEGIN /etc/grub.d/10_linux
function gfxmode {
set gfxpayload=“$1”
if [ “$1” = “keep” ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ “$linux_gfx_mode” != “text” ]; then load_video; fi
menuentry ‘Linux Mint 17 Xfce 32-bit, 3.13.0-24-generic (/dev/sda1)’ --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.13.0-24-generic root=UUID=20b8bb11-b91f-4f4c-97ab-8e8389ce785d ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.13.0-24-generic
menuentry ‘Linux Mint 17 Xfce 32-bit, 3.13.0-24-generic (/dev/sda1) – recovery mode’ --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo ‘Loading Linux 3.13.0-24-generic …’
linux /boot/vmlinuz-3.13.0-24-generic root=UUID=20b8bb11-b91f-4f4c-97ab-8e8389ce785d ro recovery nomodeset
echo ‘Loading initial ramdisk …’
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/10_lupin
END /etc/grub.d/10_lupin
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/20_memtest86+
menuentry ‘Memory test (memtest86+)’ {
insmod part_msdos
insmod ext2
else
fi
knetbsd /boot/memtest86+.elf
menuentry ‘Memory test (memtest86+, serial console 115200)’ {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
END /etc/grub.d/20_memtest86+
BEGIN /etc/grub.d/30_os-prober
menuentry ‘Linux Mint 16 Petra (16) (on /dev/sdb5)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-0ac7bd2a-3fd5-4928-b784-fe82d2b1867b’ {
insmod part_msdos
insmod ext2
set root=‘hd1,msdos5’
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,msdos5 --hint-efi=hd1,msdos5 --hint-baremetal=ahci1,msdos5 0ac7bd2a-3fd5-4928-b784-fe82d2b1867b
else
search --no-floppy --fs-uuid --set=root 0ac7bd2a-3fd5-4928-b784-fe82d2b1867b
fi
linux /boot/vmlinuz-3.11.0-12-generic root=UUID=0ac7bd2a-3fd5-4928-b784-fe82d2b1867b ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-12-generic
submenu ‘Advanced options for Linux Mint 16 Petra (16) (on /dev/sdb5)’ $menuentry_id_option ‘osprober-gnulinux-advanced-0ac7bd2a-3fd5-4928-b784-fe82d2b1867b’ {
menuentry ‘Linux Mint 16 Xfce 32-bit, 3.11.0-12-generic (/dev/sdb5) (on /dev/sdb5)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.11.0-12-generic–0ac7bd2a-3fd5-4928-b784-fe82d2b1867b’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 16 Xfce 32-bit, 3.11.0-12-generic (/dev/sdb5) – recovery mode (on /dev/sdb5)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.11.0-12-generic-root=UUID=0ac7bd2a-3fd5-4928-b784-fe82d2b1867b ro recovery nomodeset-0ac7bd2a-3fd5-4928-b784-fe82d2b1867b’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-12-generic root=UUID=0ac7bd2a-3fd5-4928-b784-fe82d2b1867b ro recovery nomodeset
if [ “${timeout}” = 0 ]; then
set timeout=10
fi
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z “${config_directory}” -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom
Hi, Mark
Hope this is what you wanted to see?
Regards,
Doug.
