Hi Guys,
I want to remove UBUNTU and install PeppermintOS2.
UBUNTU is installed alongside Windows XP. Windows says my 152GB hard drive is split C:57 GB, G:48 GB and unallocated 47 GB.
I know the unallocated 47 GB is where UBUNTU is.
I would like to know if it is ok to go in to G:/ubuntu and click on the ‘uninstall-wubi.exe’ file.?
Will this get rid of UBUNTU and leave me room to install PeppermintOS 2.
I am clinging to XP for the moment as I use Autocad and I don’t think it works too well in WINE.
Hi Mark,
I have found a folder on my G: partition that contained the UBUNTU setup.
I have deleted UBUNTU and installed PeppermintOS 2 in its place.
I have just completed Stage 7 of your tutorial (Run a System Update)
I have done as you suggest and run fdisk, with this result
Amen. I always thought WUBI was for a helper for installing Ubuntu using Windows… Whether it be installing inside it or wiping completely or dual-booting. ???
I’ve provisionally extended the size of the forum attachments folder" which was reporting as “full”
So attachment should work again now.
Not that I need the fdisk output now
I say “provisionally”, because I’m waiting to see if that’s OK with Mad Penguin … I really shouldn’t be allocationg room on his disks without his approval
