Samsung Xpress C410W
Hi All
My old HP All-in-one has now been consigned to the bin and I’ve just taken delivery of the above. I’d hoped that it would have been detected automatically on switch-on but no such luck! The supplied cd-rom seems to be just for Windows and the installation sheets only refer to Samsung’s site with reference to ‘download’ for Linux. I’ve had a good look at the site but, frankly, can’t make head nor tail of it! :-[
Could anyone point me in the right direction as to installation, please?
Thanks in advance
Rich
Run these commmands in sequence:
mkdir ~/samsung-unified-linux-driver
cd ~/samsung-unified-linux-driver
wget http://downloadcenter.samsung.com/content/DR/201403/20140312110057137/ULD_V1.00.21.tar.gz
tar xvf ULD_V1.00.21.tar.gz
cd ~/samsung-unified-linux-driver/uld
sudo ./install.sh
hit “Enter” when prompted.
When you see “–More–” hit the spacebar until you get to:-
**** Do you agree ? [y/n] :
type “y” … and hit enter.
type “Y” again at the “configure firewall” prompt … and hit enter.
When finished, see if your printer is detected if you switch it off/on again.
If it doesn’t configure automatically … add the printer in the normal way, and try one of these drivers
Samsung_C410_Series
Samsung_CLP-410_Series
Mark - WOW, that is impressive! All set up (on usb cable) and running automatically after entering the code!
I’ll have a play with my laptop’s wireless connection and get back to you on that, if needs be?
Thanks a million! (Shakes head in wonderment…)
Rich
You’re most welcome :slight_smile:
Hi Mark,
thank you for this excellent help. My Samsung C410W started working at once after I had entered the commands you gave.
Regards,
