I did not realise at the time that data could not be shared between the two systems, but that was not of great importance in that instance.
7Now I have a spare machine with a 2TB drive, Windows 7 pro and Ubuntu 12.04LTS. I would like to set this up to dual boot with a large shared data drive. I have read quite a bit about it but there seems to be conflicting advice. Is it possible and, if so, how?
It is possible. If both OS and the data drive resides in the same machine then the easiest way to share the content is to format the HDD as FAT32 (if you do not likely to have individual files that are larger than 4GiB) or to NTFS if you do.
Ubuntu will happily read and write to both of those formats.
From what I have read I need to install Windows first, then Ubuntu and create a shared partition. Should I create the partitions while I am installing Windows or Linux? How do I ensure that the data partition is accessible by both?
I realise than an alternative is running Windows programs with Wine but I have had mixed success with this.
You don’t need to worry about a seperate partition (although it wouldn’t hurt), as Ubuntu can access the Windows partition happily. Your plan is sound anyway
If I were you then I would do it this way (assuming it is all on the same HDD):
Install Windows (and make sure it is working)
Boot to LiveCD and shrink the Windows partition
Create 1 primary partition in the empty space (allowing for the shared partition) and format it to ext4
Create the second (final) primary partition to fill the rest of the HDD, for shared access and format it either to FAT32 or NTFS
Install Ubuntu into the first partition (ext4 formatted) you just created
Reboot and make sure you can boot into each OS
Once happy that all is OK then boot into Windows and map the shared partition and put some files into it
8 ) Reboot to Ubuntu and mount the shared partition (you can do that from /etc/fstab if you want it to be available at boot)
Test read & write from Ubuntu and Windows
Just yell if you need help with any of the steps above
Just a little ‘yell’ although I cannot guarantee that there will not be much louder ones later. My brain seems to have gone to sleep since I retired five years ago.
I have installed Windows 7 and that is working fine and is registered with Microsoft.
Am I right in thinking that your Item 2 is using the Ubuntu CD?
Yes, use the Ubuntu CD to boot into alive session and then fire up Gparted to shrink the windows partition.
If in doubt then poost the output from (that is lowercase L):
To see the curent (post windows install) partition layout.
I would go with chemicalfan on partition sizes of 100GB for each OS
I have successfully installed Windows 7 with a separate data partition and created a 100GB ext4 partition. This all works perfectly and I can access the data partition from other machines.
When I come to install Ubuntu have three choices the first being ‘Install Ubuntu alongside Windows 7’. Choosing this option it looks as though Ubuntu will be installed in a partition created in the ‘Data’ partition - bad. Underneath it offers advanced features which takes me to the third option; if I choose dev/sda2 ext4 I get an error messeage: No root file system is defined. Please correct this from the partitioning menu.
This is a bit like trying to describe a spiral staircase without moving your hands.
Right, done that, now it says there is no swap space partition. Do I need to go back to gparted and reduce the size of ext4 and add a swap file partiition? If so, how big should it be?
When I set up the dual-boot machine in September, but without the shared data drive there was a Ubuntu boot menu came up giving a choice of OS. This is not happening so I am only able to start Windows.
It’s a good idea to take notice of whether there are replies on a second page. So, now I am delighted to report that both systems are available at startup. I just have the problem of Ubuntu not accessing the network, but this happened in September also so I will repeat that exercise.
I don not remember seeing the request install grub to the MBR. Could you just say when this should be done so anyone coming after can do things in the right order please?
It would have been in the “Advanced” section of the “partitioning” section of the installer … the part of the Ubiquity installer where you “Allocate drive space” … IIRC it’s a drop menu at the bottom.
