I’ve decided to install gkrellm on my 12.04 instead of Conky
http://linuxforums.org.uk/index.php?topic=9747.0
I’ve found plug-ins in the Synaptic Package Manager under ‘gkrellm’ which must be the ‘basic’ ones.
When you install the weather plug-in, you have to configure it to your location, or a location nearest yours, like me in Derby, the nearest is East Midlands.
The site;
http://www.nws.noaa.gov/tg/siteloc.shtml
Is there a question in there somewhere ?
Are you wondering how to set up the sensors … or change the theme to the one in my picture … or are you having problems with the weather plugin (which BTW, I’ve never used … I figure if the Met can’t get forecasting right, what’s the point )
Dunno really, was answering myself…
