userone@office2 ~ $ dpkg -l | grep pulse
ii gstreamer0.10-pulseaudio 0.10.31-1ubuntu1.2 GStreamer plugin for PulseAudio
ii libcanberra-pulse 0.28-3ubuntu3 PulseAudio backend for libcanberra
ii libpulse-mainloop-glib0 1:1.1-0ubuntu15.3 PulseAudio client libraries (glib support)
rc libpulse-mainloop-glib0:i386 1:1.1-0ubuntu15.1 PulseAudio client libraries (glib support)
ii libpulse0 1:1.1-0ubuntu15.3 PulseAudio client libraries
ii libpulse0:i386 1:1.1-0ubuntu15.3 PulseAudio client libraries
ii libpulsedsp 1:1.1-0ubuntu15.3 PulseAudio OSS pre-load library
ii mate-media-pulse 1.2.1-5+precise MATE media utilities (PulseAudio backend)
ii mate-settings-daemon-pulse 1.2.0-4+precise daemon handling the MATE session settings (PulseAudio version)
ii pulseaudio 1:1.1-0ubuntu15.3 PulseAudio sound server
ii pulseaudio-module-bluetooth 1:1.1-0ubuntu15.3 Bluetooth module for PulseAudio sound server
ii pulseaudio-module-gconf 1:1.1-0ubuntu15.3 GConf module for PulseAudio sound server
ii pulseaudio-module-x11 1:1.1-0ubuntu15.3 X11 module for PulseAudio sound server
ii pulseaudio-utils 1:1.1-0ubuntu15.3 Command line tools for the PulseAudio sound server
ii vlc-plugin-pulse 2.0.8-0ubuntu0.12.04.1 PulseAudio plugin for VLC
rc wine1.5-amd64 1.5.6-0ubuntu1~pulse17 Microsoft Windows Compatibility Layer (64-bit support)
rc wine1.5-i386:i386 1.5.6-0ubuntu1~pulse17 Microsoft Windows Compatibility Layer (32-bit support)
userone@office2 ~ $
hope you don’t mind me hijacking this thread I just want to ask a quick question regarding pulseaudio, my Grand-Daughters sound doesn’t work at all and it hasn’t worked since upgrading to PM4 would it be worth my while trying to reset pulseaudio to defaults as per Marks instructions in the last post, if not I’ll open a new thread
This is the commands I mean
You could try resetting pulseaudio to defaults by renaming the pulseaudio config directory:
Code: [Select]
mv -v ~/.config/pulse ~/.config/pulse-old
if the above fails … the pulse config directory may be in the old position … so try:
Code: [Select]
mv -v ~/.pulse ~/.pulse-old
Code: [Select]
mv -v ~/.pulse-cookie ~/.pulse-cookie-old
Try this:-
(this will download the 32bit libpulsedsp.so file for Ubuntu 12.04, unpack it to your game directory, and preload it before running the game)
