Sound recorder doesn't record on laptop- please help!!
My sound recorder doesn’t record on my Peppermint laptop anymore guys. I don’t know why- not changed any settings.
Which sound recorder ?
It comes under sound and video and is just called sound recorder.
To give you an idea of what I’m trying to do Mark- there is a piece of music on an online radio and I’m trying to record it to send to someone who might know what it is. Usually sound recorder will record it and also record sounds in my room ( e.g me playing the piano). I just tried audacity and that’s not doing either also. Strange.
Hi Melissa,
Just a thought, and I may be wrong here. Do you have pulse audio volume control installed. Usually it`s not needed but occasionally I need it.
I think so.
Yes, I have got pulse and sound recorder is still not working- it worked fine before.
Hi Melissa,
If you open Pulse Audio, choose input device and go down to show: Monitors. That usually works for me.
@wishbone
Whilst we really appreciate your input, please do not attach images of files as attachments unless specifically asked to do so by the forum staff.
If you wish to display an image, please host it somewhere like:-
http://imgur.com
then enter it in your post using the IMG tags.
example:
http://i.imgur.com/AREwRWL.jpg
which will display as
Thanks for your understanding :slight_smile:
Received loud and clear Mark. Won`t happen again, apologies.
No need to apologise my friend, but I do have to look after the servers space … just part of the job :slight_smile:
Thanks.
I’ve done that, thanks. Will test it later…
Nope- neither Audacity or Sound recorder are recording- what am I to do!
OK, (with an active internet connection) can you run this command:
cd ~ && wget http://www.alsa-project.org/alsa-info.sh -O alsa-info.sh && bash alsa-info.sh --upload
you should then be presented with a bunch of output that ends with something similar to this:-
[b]Uploading information to [url=http://www.alsa-project.org]www.alsa-project.org[/url] ... Done!
Your ALSA information is located at http://www.alsa-project.org/db/?f=fc4b5573dd3a50c6da9248934059ea9fd192b2c2
Please inform the person helping you.[/b]
Can you post the link (the part in red) back here.
Thanks Mark:
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ cd ~ && wget http://www.alsa-project.org/alsa-info.sh -O alsa-info.sh && bash alsa-info.sh --upload
–2015-08-18 18:05:47-- http://www.alsa-project.org/alsa-info.sh
Resolving www.alsa-project.org (www.alsa-project.org)… 77.48.224.243
Connecting to www.alsa-project.org (www.alsa-project.org)|77.48.224.243|:80… connected.
HTTP request sent, awaiting response… 302 Found
Location: http://git.alsa-project.org/?p=alsa-utils.git;a=blob_plain;f=alsa-info/alsa-info.sh [following]
–2015-08-18 18:05:48-- http://git.alsa-project.org/?p=alsa-utils.git;a=blob_plain;f=alsa-info/alsa-info.sh
Resolving git.alsa-project.org (git.alsa-project.org)… 77.48.224.243
Connecting to git.alsa-project.org (git.alsa-project.org)|77.48.224.243|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [application/x-sh]
Saving to: `alsa-info.sh’
[ <=>                                   ] 27,872      --.-K/s   in 0.07s
2015-08-18 18:05:48 (376 KB/s) - `alsa-info.sh’ saved [27872]
Uploading information to www.alsa-project.org … Done!
Your ALSA information is located at http://www.alsa-project.org/db/?f=06363de28842eb98253ae661055d9aaa8741eb99
That output suggests you have “Capture” volumes set to 0 (off)
Open a terminal and run:
alsamixer
Now hit F4 to go to the capture controls
What is “Capture” set to ?
Mic.
No, I mean what are the volumes set to for “Capture” ?
run:
alsamixer
then hit F4
then take a screenshot, host it online somehere, and post a link to the image … so I can have a look
Also, isn’t Peppermint 3 out of support now?
Peppermint 3 is supported upstream till 2017 (as it’s based on Ubuntu 12.04) … there’s nothing in the Peppermint specific repo that’s likely to need any support from us, just some artwork, ice, and system configs.
