Starting SAMBA at boot up
Dear All,
It seems that the reason that I can’t use my network (Wi-Fi) Linux and Windows Boxes is that SAMBA is not running after the system boots or reboots.
Can anyone suggest how to make SAMBA start during the boot up stage.
I am running Peppermint-One.
Thanks.
See if this works…
First check samba ISN’T running:
ps ax | grep smbd
If it ISN’T running, you should get something similar to -
1034 pts/0 S+ 0:00 grep --colour=auto smbd
If it IS running, you should get something similar to -
1053 ? Ss 0:00 /usr/sbin/smbd -D 1055 ? S 0:00 /usr/sbin/smbd -D 1057 pts/0 S+ 0:00 grep --colour=auto smbd
If it ISN’T running (at bootup), open /etc/network/if-up.d/samba for editing:
sudo leafpad /etc/network/if-up.d/samba
What opens, should look like this:
[spoiler]
#!/bin/sh
Try to bring nmbd up when an interface comes up, if smbd is already running.
Don’t bother to do anything for lo.
if [ “$IFACE” = lo ]; then
exit 0
fi
Only run from ifup.
if [ “$MODE” != start ]; then
exit 0
fi
Samba only cares about inet and inet6. Get thee gone, strange people
still using ipx.
case $ADDRFAM in
inet|inet6|NetworkManager)
exit 0
esac
status=$(/etc/init.d/samba status)
Really only necessary to do anything if nmbd is not already running
if echo “$status” | grep -q ‘smbd is running’
&& ! echo “$status” | grep -q ‘nmbd is running’
/etc/init.d/samba start
fi
exit 0
[/spoiler]
Add a line, just above the exit 0 line, that reads
service samba restart
So it now reads -
[spoiler]
#!/bin/sh
exit 0
fi
Only run from ifup.
exit 0
fi
still using ipx.
case $ADDRFAM in
exit 0
esac
fi
exit 0
[/spoiler]
SAVE the file, and reboot… now test again with
ps ax | grep smbd
Working much better now have noted that Linux machine needs to be started first, do not know why .
Thank you.
