Hello,
I have recently installed , Fedora 20 Os in my PC but the Wireless don’t work .
Can anyone help me to fix this ?
Thank you.
Hello,
Thank you.
Open a terminal and post the output from running these commands:
lshw -C network
lspci -vnn | grep net
lsusb
[root@localhost chrifmarwen]# lshw -C network
bash: lshw: unknown comand…
[root@localhost chrifmarwen]# lspci -vnn | grep net
02:00.0 Ethernet controller [0200]: Broadcom Corporation NetLink BCM57785 Gigabit Ethernet PCIe [14e4:16b5] (rev 10)
[root@localhost chrifmarwen]# lsub
bash: lsub: unknown comand…
Is this a USB wireless adapter ?
Try
lsusb
again, as you made a typo in your last attempt
No it’s not usd wireless, it’s embeded.
Wired connection work fine .
[chrifmarwen@localhost ~]$ lsusb
Bus 002 Device 003: ID 8564:1000
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0489:e010 Foxconn / Hon Hai
Bus 001 Device 003: ID 064e:d250 Suyin Corp.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
[chrifmarwen@localhost ~]$ lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation 2nd Generation Core Processor Family DRAM Controller [8086:0104] (rev 09)
Subsystem: Acer Incorporated [ALI] Device [1025:0504]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:02.0 VGA compatible controller [0300]: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller [8086:0116] (rev 09) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 49
Memory at b0000000 (64-bit, non-prefetchable) [size=4M]
Memory at a0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 2000 [size=64]
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
00:16.0 Communication controller [0780]: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 [8086:1c3a] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 50
Memory at b0704000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
00:1a.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 [8086:1c2d] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at b070a000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 51
Memory at b0700000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: 9fb00000-9fbfffff
Prefetchable memory behind bridge: 00000000b0400000-00000000b04fffff
Kernel driver in use: pcieport
00:1c.1 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 [8086:1c12] (rev b4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: b0600000-b06fffff
00:1c.3 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 [8086:1c16] (rev b4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: b0500000-b05fffff
00:1d.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 [8086:1c26] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at b0709000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge [0601]: Intel Corporation HM65 Express Chipset Family LPC Controller [8086:1c49] (rev 04)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller [8086:1c03] (rev 04) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 40
I/O ports at 2088 [size=8]
I/O ports at 209c [size=4]
I/O ports at 2080 [size=8]
I/O ports at 2098 [size=4]
I/O ports at 2060 [size=32]
Memory at b0708000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller [8086:1c22] (rev 04)
Flags: medium devsel, IRQ 19
Memory at b0706000 (64-bit, non-prefetchable) [size=256]
I/O ports at 2040 [size=32]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at b0430000 (64-bit, prefetchable) [size=64K]
Memory at b0440000 (64-bit, prefetchable) [size=64K]
Expansion ROM at b0450000 [disabled] [size=2K]
Kernel driver in use: tg3
02:00.1 SD Host controller [0805]: Broadcom Corporation BCM57765/57785 SDXC/MMC Card Reader [14e4:16bc] (rev 10) (prog-if 01)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at b0400000 (64-bit, prefetchable) [size=64K]
Kernel driver in use: sdhci-pci
02:00.2 System peripheral [0880]: Broadcom Corporation BCM57765/57785 MS Card Reader [14e4:16be] (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 7
Memory at b0410000 (64-bit, prefetchable) [size=64K]
02:00.3 System peripheral [0880]: Broadcom Corporation BCM57765/57785 xD-Picture Card Reader [14e4:16bf] (rev 10)
Memory at b0420000 (64-bit, prefetchable) [size=64K]
03:00.0 Network controller [0280]: Broadcom Corporation BCM43227 802.11b/g/n [14e4:4358]
Subsystem: Foxconn International, Inc. Device [105b:e040]
Memory at b0600000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: bcma-pci-bridge
05:00.0 USB controller [0c03]: NEC Corporation uPD720200 USB 3.0 Host Controller [1033:0194] (rev 04) (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at b0500000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: xhci_hcd
With an active (wired) internet connection, run:
su
yum install akmod-wl
it works ! Thinks !
You’re welcome
If you now consider this issue solved, can you please edit the FIRST posting in this topic and change
Subject: No Wireless connection Fedora 20 (SOLVED)
Thanks in advance
Hello,
I’ve another problem after updating feedora 20, but now the wireless led is on but no internet connection.
can anyone help me pleas ?
what’s the output from:
rfkill list
bash: rfkill: not known
You might need to install it:
su
yum install rfkill
[root@localhost chrifmarwen]# rfkill list
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
5: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Let’s try uninstalling/reinstalling the driver again … make sure you’re connected to your router with an ethernet cable, then run:
su
yum remove akmod-wl
I make this done but no result : the led is off now , i tried fn + f3 to activate it but it dosn’t.
now what’s the output from
rfkill list
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
ifconfig
iwconfig
iwlist scanning
[root@localhost chrifmarwen]# ifconfig
em1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:70:f4:aa:87:64 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 0 (Boucle locale)
RX packets 936 bytes 81360 (79.4 KiB)
TX packets 936 bytes 81360 (79.4 KiB)
[root@localhost chrifmarwen]# iwconfig
lo no wireless extensions.
em1 no wireless extensions.
[root@localhost chrifmarwen]# iwlist scanning
lo Interface doesn't support scanning.
em1 Interface doesn't support scanning.
install lshw:
yum install lshw
then post the output from:
lshw -C network
