Support from Zone Alarm
I was just browsing the web to see what I could find about Firewalls & Virus Killers for linux and found this;
http://img341.imageshack.us/img341/9763/zanolinux.th.jpg
Quite offended by what the guy said, ‘Hello,Our software is not designed to run with anything less than XP SP2.since your using an OS which is not officially supported. XP with no service packs installed is not supported by us.Forum Moderator’
I thought, 'The cheeky little ********. How can he say linux is a less than ANYTHING Windows.
Well there is the old joke -
The box said ‘Requires Windows 7 or better’. So I installed LINUX
updated a bit from
The box said ‘Requires Windows 95 or better’. So I installed LINUX
If that message had a ‘Like’ on it, I would have clicked on it ;D
