syslog.conf question [SOLVED]
Hey guys!
it has been a long time since I have posted on here but the rest of the internet is not helping me with this current issue so I thought I’d try here.
I have a line in /etc/syslog.conf;
log user info
user.notice /var/log/log_filename
I was just wondering if there is anywhere I can set the permissions of the log file when it is generated. For the time being I have set the permissions manually but in case the file is ever removed I need the new log file to have certain perms.
Cheers in advance
I know this doesn’t directly answer your question, but it looks like the syslog is generated by an account called “notice”
wouldn’t it be easier just to add yourself to the “notice” group ?
Could you not direct the output to a sub folder of /var/log/sub/log_filename and change the permissions of that folder?
Cheers for your help guys.
I will put the subfolder idea to the user.
I also found that you can use /etc/logrotate.d/ to specify conditions.
Nice … I’ve learned something new :slight_smile: … I’d never looked at the files in logrotate.d before.
Same here. Although I’m having an error with the create line. Syntax is fine, I’m just trying to get to the bottom of it.
Sorted!
Incorrect information was the issue. When writing the file in /etc/logrotate.d/ make sure the closing bracket ‘}’ is on a new line.
