Trying to get TVTime working
I’ve just installed Ubuntu Studio on a spare partition and I’m trying to get TVTime working but it tells me that I do not have a signal.
Cannot open capture device /dev/video0. I remember the trouble I had before so I have removed my webcam, that didn’t solve anything…
sudo lshw
[spoiler]description: Desktop Computer
product: System Product Name (To Be Filled By O.E.M.)
vendor: System manufacturer
version: System Version
serial: System Serial Number
width: 64 bits
capabilities: smbios-2.5 dmi-2.5 vsyscall32
configuration: boot=normal chassis=desktop family=To Be Filled By O.E.M. sku=To Be Filled By O.E.M. uuid=6044E46A-26FF-D511-83E3-7824AF3597E7
*-core
description: Motherboard
product: M5A78L-M/USB3
vendor: ASUSTeK Computer INC.
physical id: 0
version: Rev X.0x
serial: 140627315101294
slot: To Be Filled By O.E.M.
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 2001
date: 09/11/2014
capacity: 1984KiB
capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
*-cpu
description: CPU
product: AMD Phenom™ II X4 965 Processor
vendor: Advanced Micro Devices [AMD]
physical id: 4
bus info: cpu@0
version: AMD Phenom™ II X4 965 Processor
serial: To Be Filled By O.E.M.
slot: AM3R2
capacity: 3400MHz
width: 64 bits
clock: 200MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp 3dnowext 3dnow constant_tsc rep_good nopl nonstop_tsc extd_apicid pni monitor cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt nodeid_msr hw_pstate npt lbrv svm_lock nrip_save cpufreq
configuration: cores=4 enabledcores=4 threads=4
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 512KiB
clock: 1GHz (1.0ns)
capabilities: pipeline-burst internal write-back unified
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 2MiB
clock: 1GHz (1.0ns)
*-cache:2
description: L3 cache
physical id: 7
slot: L3-Cache
capacity: 6MiB
clock: 1GHz (1.0ns)
*-memory
description: System Memory
physical id: 32
slot: System board or motherboard
*-bank:0
description: DIMMProject-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME EMAIL@ADDRESSPOT-Creation-Date: 2009-10-08 14:02+0200PO-Revision-Date: 2012-02-05 00:26+0000Last-Translator: Andi Chandler Language-Team: English (United Kingdom) [email protected]MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2014-11-10 11:11+0000X-Generator: Launchpad (build 17241) Synchronous 1333 MHz (0.8 ns)
product: PartNum0
vendor: Manufacturer0
physical id: 0
serial: SerNum0
slot: DIMM0
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
description: DIMMProject-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME EMAIL@ADDRESSPOT-Creation-Date: 2009-10-08 14:02+0200PO-Revision-Date: 2012-02-05 00:26+0000Last-Translator: Andi Chandler Language-Team: English (United Kingdom) [email protected]MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2014-11-10 11:11+0000X-Generator: Launchpad (build 17241) [empty]
product: PartNum1
vendor: Manufacturer1
physical id: 1
serial: SerNum1
slot: DIMM1
*-bank:2
product: PartNum2
vendor: Manufacturer2
physical id: 2
serial: SerNum2
slot: DIMM2
*-bank:3
product: PartNum3
vendor: Manufacturer3
physical id: 3
serial: SerNum3
slot: DIMM3
*-pci:0
description: Host bridge
product: RS780 Host Bridge
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 66MHz
*-pci:0
description: PCI bridge
product: AMD RS780/RS880 PCI to PCI bridge (int gfx)
vendor: ASUSTeK Computer Inc.
physical id: 1
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: pci ht normal_decode bus_master cap_list
resources: ioport:d000(size=4096) memory:fe900000-feafffff ioport:d0000000(size=268435456)
*-display
product: RS780L [Radeon 3000]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 5
bus info: pci@0000:01:05.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:18 memory:d0000000-dfffffff ioport:d000(size=256) memory:feaf0000-feafffff memory:fe900000-fe9fffff
*-multimedia
description: Audio device
product: RS780 HDMI Audio [Radeon (HD) 3000 Series]
physical id: 5.1
bus info: pci@0000:01:05.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:19 memory:feae8000-feaebfff
*-pci:1
product: RS780/RS880 PCI to PCI bridge (PCIE port 3)
physical id: 7
bus info: pci@0000:00:07.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:40 memory:feb00000-febfffff
*-usb
description: USB controller
product: ASMedia Technology Inc.
vendor: ASMedia Technology Inc.
physical id: 0
bus info: pci@0000:02:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: msi msix pm pciexpress xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:19 memory:febf0000-febf7fff
*-pci:2
product: RS780/RS880 PCI to PCI bridge (PCIE port 5)
physical id: a
bus info: pci@0000:00:0a.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:41 ioport:e000(size=4096) ioport:fdf00000(size=1048576)
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth0
version: 09
serial: 78:24:af:35:97:e7
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168f-1_0.0.5 06/18/12 ip=192.168.1.8 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:47 ioport:e800(size=256) memory:fdfff000-fdffffff memory:fdff8000-fdffbfff
*-storage
description: SATA controller
product: SB7x0/SB8x0/SB9x0 SATA Controller [IDE mode]
physical id: 11
bus info: pci@0000:00:11.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: storage pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=64
resources: irq:22 ioport:c000(size=8) ioport:b000(size=4) ioport:a000(size=8) ioport:9000(size=4) ioport:8000(size=16) memory:fe8ffc00-fe8fffff
*-usb:0
product: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
physical id: 12
bus info: pci@0000:00:12.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: ohci bus_master
configuration: driver=ohci-pci latency=64
resources: irq:16 memory:fe8fe000-fe8fefff
*-usb:1
product: SB7x0 USB OHCI1 Controller
physical id: 12.1
bus info: pci@0000:00:12.1
version: 00
width: 32 bits
clock: 66MHz
resources: irq:16 memory:fe8fd000-fe8fdfff
*-usb:2
product: SB7x0/SB8x0/SB9x0 USB EHCI Controller
physical id: 12.2
bus info: pci@0000:00:12.2
version: 00
width: 32 bits
clock: 66MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=64
resources: irq:17 memory:fe8ff800-fe8ff8ff
*-usb:3
physical id: 13
bus info: pci@0000:00:13.0
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:fe8fc000-fe8fcfff
*-usb:4
physical id: 13.1
bus info: pci@0000:00:13.1
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:fe8fb000-fe8fbfff
*-usb:5
physical id: 13.2
bus info: pci@0000:00:13.2
version: 00
width: 32 bits
clock: 66MHz
resources: irq:19 memory:fe8ff400-fe8ff4ff
*-serial UNCLAIMED
description: SMBus
product: SBx00 SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 3c
width: 32 bits
clock: 66MHz
capabilities: ht cap_list
configuration: latency=0
*-ide
description: IDE interface
product: SB7x0/SB8x0/SB9x0 IDE Controller
physical id: 14.1
bus info: pci@0000:00:14.1
version: 00
width: 32 bits
clock: 66MHz
capabilities: ide msi bus_master cap_list
configuration: driver=pata_atiixp latency=64
resources: irq:16 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff00(size=16)
*-multimedia
product: SBx00 Azalia (Intel HDA)
physical id: 14.2
bus info: pci@0000:00:14.2
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_hda_intel latency=64
resources: irq:16 memory:fe8f4000-fe8f7fff
*-isa
description: ISA bridge
product: SB7x0/SB8x0/SB9x0 LPC host controller
physical id: 14.3
bus info: pci@0000:00:14.3
version: 00
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
*-pci:3
product: SBx00 PCI to PCI Bridge
physical id: 14.4
bus info: pci@0000:00:14.4
version: 00
width: 32 bits
clock: 66MHz
capabilities: pci subtractive_decode bus_master
*-usb:6
product: SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
physical id: 14.5
bus info: pci@0000:00:14.5
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:fe8fa000-fe8fafff
*-pci:1
product: Family 10h Processor HyperTransport Configuration
physical id: 101
bus info: pci@0000:00:18.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
product: Family 10h Processor Address Map
physical id: 102
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
product: Family 10h Processor DRAM Controller
physical id: 103
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
product: Family 10h Processor Miscellaneous Control
physical id: 104
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=k10temp
resources: irq:0
*-pci:5
product: Family 10h Processor Link Control
physical id: 105
bus info: pci@0000:00:18.4
version: 00
width: 32 bits
clock: 33MHz
*-scsi:0
physical id: 1
logical name: scsi1
capabilities: emulated
*-disk
description: ATA Disk
product: Hitachi HDS5C302
vendor: Hitachi
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/sda
version: ML6O
serial: ML2220F31TWRZE
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 sectorsize=512 signature=0009b408
*-volume
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@1:0.0.0,1
logical name: /dev/sda1
version: 1.0
serial: 3211899a-4095-4d76-8d34-70c534d52374
capacity: 1863GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
configuration: created=2014-07-13 12:36:05 filesystem=ext4 label=Drive3 lastmountpoint=/media/Drive3 modified=2015-01-12 00:14:08 mounted=2015-01-12 00:11:09 state=clean
*-cdrom
description: DVD-RAM writer
product: iHAS122 E
vendor: ATAPI
physical id: 0.1.0
bus info: scsi@1:0.1.0
logical name: /dev/cdrom
logical name: /dev/sr0
version: 2L04
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-scsi:1
physical id: 2
logical name: scsi2
*-disk
product: ST500DM002-1BD14
vendor: Seagate
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sdb
version: KC45
serial: Z3T2EK9X
configuration: ansiversion=5 sectorsize=4096 signature=000e97af
*-volume:0
vendor: Linux
physical id: 1
bus info: scsi@2:0.0.0,1
logical name: /dev/sdb1
version: 1.0
serial: 8529457d-1193-4c25-a5a9-8f47167ef356
capacity: 149GiB
configuration: created=2014-12-11 12:15:40 filesystem=ext4 lastmountpoint=/ modified=2015-01-12 00:11:08 mounted=2015-01-12 00:11:08 state=clean
*-volume:1
description: Linux swap volume
physical id: 2
bus info: scsi@2:0.0.0,2
logical name: /dev/sdb2
version: 1
serial: 718377f7-8759-44ad-888d-e0fb3f91c5e4
capacity: 8GiB
capabilities: primary nofs swap initialized
configuration: filesystem=swap pagesize=4096
*-volume:2
description: Extended partition
physical id: 3
bus info: scsi@2:0.0.0,3
logical name: /dev/sdb3
capacity: 300GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume:0
description: Linux filesystem partition
physical id: 5
logical name: /dev/sdb5
logical name: /
capacity: 149GiB
configuration: mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered state=mounted
*-logicalvolume:1
physical id: 6
logical name: /dev/sdb6
capacity: 149GiB
*-scsi:2
physical id: 3
logical name: scsi4
*-disk
product: Maxtor 6V250F0
vendor: Maxtor
physical id: 0.0.0
bus info: scsi@4:0.0.0
logical name: /dev/sdc
version: VA11
serial: V5089VDG
configuration: ansiversion=5 sectorsize=512 signature=0008a747
*-volume
vendor: Linux
physical id: 1
bus info: scsi@4:0.0.0,1
logical name: /dev/sdc1
version: 1.0
serial: dddc4450-4992-45d6-9d6b-13467e140260
capacity: 233GiB
configuration: created=2014-09-18 16:44:42 filesystem=ext4 label=Drive2 lastmountpoint=/media/Drive2 modified=2015-01-12 00:14:08 mounted=2015-01-12 00:11:09 state=clean
*-scsi:3
physical id: 5
logical name: scsi5
*-disk
product: MAXTOR STM325082
vendor: Maxtor
physical id: 0.0.0
bus info: scsi@5:0.0.0
logical name: /dev/sdd
version: 3.AA
serial: 9QE1417X
configuration: ansiversion=5 sectorsize=512 signature=000b090e
*-volume
vendor: Linux
physical id: 1
bus info: scsi@5:0.0.0,1
logical name: /dev/sdd1
version: 1.0
serial: d5e1db61-b980-4624-801c-e0546b288b8f
capacity: 232GiB
configuration: created=2012-10-13 13:39:41 filesystem=ext4 label=Drive1 lastmountpoint=/media/Drive1 modified=2015-01-12 00:14:08 mounted=2015-01-12 00:11:09 state=clean
*-scsi:4
physical id: 6
bus info: usb@2:3
logical name: scsi6
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk:0
description: SCSI Disk
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sde
configuration: sectorsize=512
*-disk:1
physical id: 0.0.1
bus info: scsi@6:0.0.1
logical name: /dev/sdf
*-disk:2
physical id: 0.0.2
bus info: scsi@6:0.0.2
logical name: /dev/sdg
*-disk:3
physical id: 0.0.3
bus info: scsi@6:0.0.3
logical name: /dev/sdh
*-scsi:5
physical id: 7
bus info: usb@9:1
logical name: scsi7
*-disk
product: External USB 3.0
vendor: Toshiba
physical id: 0.0.0
bus info: scsi@7:0.0.0
logical name: /dev/sdi
version: 0201
serial: 81573573
configuration: ansiversion=6 sectorsize=4096 signature=a0ee6df5
*-volume UNCLAIMED
description: HPFS/NTFS partition
physical id: 1
bus info: scsi@7:0.0.0,1
capacity: 349GiB
*-scsi:6
physical id: 8
bus info: usb@9:2
logical name: scsi8
*-disk
vendor: Toshiba
physical id: 0.0.0
bus info: scsi@8:0.0.0
logical name: /dev/sdj
version: 0201
serial: 66B01265
configuration: ansiversion=6 sectorsize=4096 signature=000104b7
*-volume UNCLAIMED
physical id: 1
bus info: scsi@8:0.0.0,1
capacity: 349GiB
capabilities: primary bootable[/spoiler]
Hi Pooky
What are you using for a capture device ?
I don’t see anything in your hardware list, or are you trying to capture the webcam ?
I think it may be dead!
Old thread about same TV Card
http://linuxforums.org.uk/index.php?topic=9778.msg69944#msg69944
Look trough your dmesg output
gedit /var/log/dmesg
to see if there are any clues why it’s either not being detected, or is being disabled.
I can’t see anything. Not entirely sure what I’m looking for though.
I have looked through it and found some stuff , which I have put a blank line before and after. Could you let me know what you think Mark.
[spoiler][ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.13.0-43-generic (buildd@tipua) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #72-Ubuntu SMP Mon Dec 8 19:35:06 UTC 2014 (Ubuntu 3.13.0-43.72-generic 3.13.11.11)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-43-generic root=UUID=8529457d-1193-4c25-a5a9-8f47167ef356 ro quiet splash
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cfe7ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cfe80000-0x00000000cfe97fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cfe98000-0x00000000cfebffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cfec0000-0x00000000cfefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffe00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer System Product Name/M5A78L-M/USB3, BIOS 2001 09/11/2014
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] No AGP bridge found
[ 0.000000] e820: last_pfn = 0x220000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000230000000 aka 8960M
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xcfe80 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000099000] 99000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] BRK [0x01fe1000, 0x01fe1fff] PGTABLE
[ 0.000000] BRK [0x01fe2000, 0x01fe2fff] PGTABLE
[ 0.000000] BRK [0x01fe3000, 0x01fe3fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x21fe00000-0x21fffffff]
[ 0.000000] [mem 0x21fe00000-0x21fffffff] page 2M
[ 0.000000] BRK [0x01fe4000, 0x01fe4fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x21c000000-0x21fdfffff]
[ 0.000000] [mem 0x21c000000-0x21fdfffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x200000000-0x21bffffff]
[ 0.000000] [mem 0x200000000-0x21bffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0xcfe7ffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x3fffffff] page 2M
[ 0.000000] [mem 0x40000000-0xbfffffff] page 1G
[ 0.000000] [mem 0xc0000000-0xcfdfffff] page 2M
[ 0.000000] [mem 0xcfe00000-0xcfe7ffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x100000000-0x1ffffffff]
[ 0.000000] [mem 0x100000000-0x1ffffffff] page 1G
[ 0.000000] RAMDISK: [mem 0x34c28000-0x3660bfff]
[ 0.000000] ACPI: RSDP 00000000000fb490 000024 (v02 ACPIAM)
[ 0.000000] ACPI: XSDT 00000000cfe80100 000054 (v01 091114 XSDT1103 20140911 MSFT 00000097)
[ 0.000000] ACPI: FACP 00000000cfe80290 0000F4 (v03 091114 FACP1103 20140911 MSFT 00000097)
[ 0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20131115/tbfadt-603)
[ 0.000000] ACPI: DSDT 00000000cfe80460 00DBCE (v01 A1887 A1887001 00000001 INTL 20060113)
[ 0.000000] ACPI: FACS 00000000cfe98000 000040
[ 0.000000] ACPI: APIC 00000000cfe80390 00008C (v01 091114 APIC1103 20140911 MSFT 00000097)
[ 0.000000] ACPI: MCFG 00000000cfe80420 00003C (v01 091114 OEMMCFG 20140911 MSFT 00000097)
[ 0.000000] ACPI: OEMB 00000000cfe98040 000072 (v01 091114 OEMB1103 20140911 MSFT 00000097)
[ 0.000000] ACPI: HPET 00000000cfe8f460 000038 (v01 091114 OEMHPET 20140911 MSFT 00000097)
[ 0.000000] ACPI: SSDT 00000000cfe8f4a0 0008BC (v01 A M I POWERNOW 00000001 AMD 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Scanning NUMA topology in Northbridge 24
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000021fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x21fffffff]
[ 0.000000] NODE_DATA [mem 0x21fff9000-0x21fffdfff]
[ 0.000000] [ffffea0000000000-ffffea00087fffff] PMD → [ffff880217a00000-ffff88021f5fffff] on node 0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] DMA32 [mem 0x01000000-0xffffffff]
[ 0.000000] Normal [mem 0x100000000-0x21fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[ 0.000000] node 0: [mem 0x00100000-0xcfe7ffff]
[ 0.000000] node 0: [mem 0x100000000-0x21fffffff]
[ 0.000000] On node 0 totalpages: 2031134
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 13242 pages used for memmap
[ 0.000000] DMA32 zone: 847488 pages, LIFO batch:31
[ 0.000000] Normal zone: 18432 pages used for memmap
[ 0.000000] Normal zone: 1179648 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x84] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x85] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x86] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x87] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8300 base: 0xfed00000
[ 0.000000] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcfe80000-0xcfe97fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcfe98000-0xcfebffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcfec0000-0xcfefffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcff00000-0xffdfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffe00000-0xffffffff]
[ 0.000000] e820: [mem 0xcff00000-0xffdfffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff88021fc00000 s82304 r8192 d24192 u262144
[ 0.000000] pcpu-alloc: s82304 r8192 d24192 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1999375
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-43-generic root=UUID=8529457d-1193-4c25-a5a9-8f47167ef356 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture…
[ 0.000000] Node 0: aperture @ 0 size 32 MB
[ 0.000000] Your BIOS doesn’t leave a aperture memory hole
[ 0.000000] Please enable the IOMMU option in the BIOS setup
[ 0.000000] This costs you 64 MB of RAM
[ 0.000000] Mapping aperture over 65536 KB of RAM @ c4000000
[ 0.000000] PM: Registered nosave memory: [mem 0xc4000000-0xc7ffffff]
[ 0.000000] Memory: 7821920K/8124536K available (7383K kernel code, 1144K rwdata, 3408K rodata, 1336K init, 1444K bss, 302616K reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Offload RCU callbacks from all CPUs
[ 0.000000] Offload RCU callbacks from CPUs: 0-7.
[ 0.000000] NR_IRQS:16640 nr_irqs:744 16
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] allocated 32505856 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.004000] tsc: Detected 3415.223 MHz processor
[ 0.000005] Calibrating delay loop (skipped), value calculated using timer frequency… 6830.44 BogoMIPS (lpj=13660892)
[ 0.000008] pid_max: default: 32768 minimum: 301
[ 0.000037] Security Framework initialized
[ 0.000060] AppArmor: AppArmor initialized
[ 0.000061] Yama: becoming mindful.
[ 0.000540] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.003411] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.004800] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004809] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.005079] Initializing cgroup subsys memory
[ 0.005087] Initializing cgroup subsys devices
[ 0.005089] Initializing cgroup subsys freezer
[ 0.005091] Initializing cgroup subsys blkio
[ 0.005093] Initializing cgroup subsys perf_event
[ 0.005095] Initializing cgroup subsys hugetlb
[ 0.005113] tseg: 0000000000
[ 0.005120] CPU: Physical Processor ID: 0
[ 0.005121] CPU: Processor Core ID: 0
[ 0.005122] mce: CPU supports 6 MCE banks
[ 0.005128] LVT offset 0 assigned for vector 0xf9
[ 0.005134] Last level iTLB entries: 4KB 512, 2MB 16, 4MB 8
[ 0.005134] Last level dTLB entries: 4KB 512, 2MB 128, 4MB 64
[ 0.005134] tlb_flushall_shift: 4
[ 0.005220] Freeing SMP alternatives memory: 32K (ffffffff81e6e000 - ffffffff81e76000)
[ 0.005902] ACPI: Core revision 20131115
[ 0.008754] ACPI: All ACPI Tables successfully acquired
[ 0.016054] ftrace: allocating 28552 entries in 112 pages
[ 0.026109] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.065816] smpboot: CPU0: AMD Phenom™ II X4 965 Processor (fam: 10, model: 04, stepping: 03)
[ 0.171696] Performance Events: AMD PMU driver.
[ 0.171700] … version: 0
[ 0.171701] … bit width: 48
[ 0.171701] … generic registers: 4
[ 0.171702] … value mask: 0000ffffffffffff
[ 0.171703] … max period: 00007fffffffffff
[ 0.171704] … fixed-purpose events: 0
[ 0.171704] … event mask: 000000000000000f
[ 0.173108] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.173179] x86: Booting SMP configuration:
[ 0.173180] … node #0, CPUs: #1 #2 #3
[ 0.212429] x86: Booted up 1 node, 4 CPUs
[ 0.212431] smpboot: Total of 4 processors activated (27321.78 BogoMIPS)
[ 0.216963] devtmpfs: initialized
[ 0.219787] EVM: security.selinux
[ 0.219789] EVM: security.SMACK64
[ 0.219790] EVM: security.ima
[ 0.219790] EVM: security.capability
[ 0.219871] PM: Registering ACPI NVS region [mem 0xcfe98000-0xcfebffff] (163840 bytes)
[ 0.220656] pinctrl core: initialized pinctrl subsystem
[ 0.220706] regulator-dummy: no parameters
[ 0.220731] RTC time: 12:41:18, date: 01/12/15
[ 0.220762] NET: Registered protocol family 16
[ 0.220846] cpuidle: using governor ladder
[ 0.220847] cpuidle: using governor menu
[ 0.220851] node 0 link 0: io port [1000, ffffff]
[ 0.220853] TOM: 00000000d0000000 aka 3328M
[ 0.220855] Fam 10h mmconf [mem 0xe0000000-0xefffffff]
[ 0.220857] node 0 link 0: mmio [a0000, bffff]
[ 0.220859] node 0 link 0: mmio [d0000000, efffffff] ==> [d0000000, dfffffff]
[ 0.220861] node 0 link 0: mmio [f0000000, fe8fffff]
[ 0.220862] node 0 link 0: mmio [fe900000, feafffff]
[ 0.220863] node 0 link 0: mmio [feb00000, ffdfffff]
[ 0.220864] TOM2: 0000000230000000 aka 8960M
[ 0.220866] bus: [bus 00-1f] on node 0 link 0
[ 0.220867] bus: 00 [io 0x0000-0xffff]
[ 0.220868] bus: 00 [mem 0x000a0000-0x000bffff]
[ 0.220869] bus: 00 [mem 0xd0000000-0xdfffffff]
[ 0.220870] bus: 00 [mem 0xf0000000-0xffffffff]
[ 0.220871] bus: 00 [mem 0x230000000-0xfcffffffff]
[ 0.220920] ACPI: bus type PCI registered
[ 0.220922] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.220969] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.220970] PCI: not using MMCONFIG
[ 0.220971] PCI: Using configuration type 1 for base access
[ 0.220972] PCI: Using configuration type 1 for extended access
[ 0.221119] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.221120] mtrr: probably your BIOS does not setup all CPUs.
[ 0.221121] mtrr: corrected configuration.
[ 0.221791] bio: create slab at 0
[ 0.221934] ACPI: Added _OSI(Module Device)
[ 0.221935] ACPI: Added _OSI(Processor Device)
[ 0.221936] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.221937] ACPI: Added OSI(Processor Aggregator Device)
[ 0.224039] ACPI: Executed 3 blocks of module-level executable AML code
[ 0.328181] ACPI: Interpreter enabled
[ 0.328191] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [_S2
] (20131115/hwxface-580)
[ 0.328201] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.328203] ACPI: Using IOAPIC for interrupt routing
[ 0.328217] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.329140] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.336139] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.336214] ACPI: No dock devices found.
[ 0.380628] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.380633] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.380636] acpi PNP0A03:00: OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.380856] PCI host bridge to bus 0000:00
[ 0.380858] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.380860] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.380861] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.380863] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.380864] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff]
[ 0.380865] pci_bus 0000:00: root bus resource [mem 0xcff00000-0xdfffffff]
[ 0.380867] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfebfffff]
[ 0.380875] pci 0000:00:00.0: [1022:9600] type 00 class 0x060000
[ 0.380951] pci 0000:00:01.0: [1043:9602] type 01 class 0x060400
[ 0.381018] pci 0000:00:07.0: [1022:9607] type 01 class 0x060400
[ 0.381044] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.381075] pci 0000:00:07.0: System wakeup disabled by ACPI
[ 0.381097] pci 0000:00:0a.0: [1022:9609] type 01 class 0x060400
[ 0.381124] pci 0000:00:0a.0: PME# supported from D0 D3hot D3cold
[ 0.381153] pci 0000:00:0a.0: System wakeup disabled by ACPI
[ 0.381186] pci 0000:00:11.0: [1002:4390] type 00 class 0x01018f
[ 0.381204] pci 0000:00:11.0: reg 0x10: [io 0xc000-0xc007]
[ 0.381212] pci 0000:00:11.0: reg 0x14: [io 0xb000-0xb003]
[ 0.381221] pci 0000:00:11.0: reg 0x18: [io 0xa000-0xa007]
[ 0.381229] pci 0000:00:11.0: reg 0x1c: [io 0x9000-0x9003]
[ 0.381237] pci 0000:00:11.0: reg 0x20: [io 0x8000-0x800f]
[ 0.381246] pci 0000:00:11.0: reg 0x24: [mem 0xfe8ffc00-0xfe8fffff]
[ 0.381264] pci 0000:00:11.0: set SATA to AHCI mode
[ 0.381340] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
[ 0.381352] pci 0000:00:12.0: reg 0x10: [mem 0xfe8fe000-0xfe8fefff]
[ 0.381428] pci 0000:00:12.0: System wakeup disabled by ACPI
[ 0.381451] pci 0000:00:12.1: [1002:4398] type 00 class 0x0c0310
[ 0.381463] pci 0000:00:12.1: reg 0x10: [mem 0xfe8fd000-0xfe8fdfff]
[ 0.381538] pci 0000:00:12.1: System wakeup disabled by ACPI
[ 0.381563] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
[ 0.381581] pci 0000:00:12.2: reg 0x10: [mem 0xfe8ff800-0xfe8ff8ff]
[ 0.381656] pci 0000:00:12.2: supports D1 D2
[ 0.381658] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.381690] pci 0000:00:12.2: System wakeup disabled by ACPI
[ 0.381715] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
[ 0.381727] pci 0000:00:13.0: reg 0x10: [mem 0xfe8fc000-0xfe8fcfff]
[ 0.381803] pci 0000:00:13.0: System wakeup disabled by ACPI
[ 0.381822] pci 0000:00:13.1: [1002:4398] type 00 class 0x0c0310
[ 0.381834] pci 0000:00:13.1: reg 0x10: [mem 0xfe8fb000-0xfe8fbfff]
[ 0.381911] pci 0000:00:13.1: System wakeup disabled by ACPI
[ 0.381935] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
[ 0.381952] pci 0000:00:13.2: reg 0x10: [mem 0xfe8ff400-0xfe8ff4ff]
[ 0.382028] pci 0000:00:13.2: supports D1 D2
[ 0.382029] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.382061] pci 0000:00:13.2: System wakeup disabled by ACPI
[ 0.382089] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
[ 0.382212] pci 0000:00:14.1: [1002:439c] type 00 class 0x01018a
[ 0.382227] pci 0000:00:14.1: reg 0x10: [io 0x0000-0x0007]
[ 0.382235] pci 0000:00:14.1: reg 0x14: [io 0x0000-0x0003]
[ 0.382243] pci 0000:00:14.1: reg 0x18: [io 0x0000-0x0007]
[ 0.382251] pci 0000:00:14.1: reg 0x1c: [io 0x0000-0x0003]
[ 0.382259] pci 0000:00:14.1: reg 0x20: [io 0xff00-0xff0f]
[ 0.382348] pci 0000:00:14.2: [1002:4383] type 00 class 0x040300
[ 0.382368] pci 0000:00:14.2: reg 0x10: [mem 0xfe8f4000-0xfe8f7fff 64bit]
[ 0.382428] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.382459] pci 0000:00:14.2: System wakeup disabled by ACPI
[ 0.382479] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
[ 0.382581] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
[ 0.382637] pci 0000:00:14.4: System wakeup disabled by ACPI
[ 0.382658] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310
[ 0.382670] pci 0000:00:14.5: reg 0x10: [mem 0xfe8fa000-0xfe8fafff]
[ 0.382745] pci 0000:00:14.5: System wakeup disabled by ACPI
[ 0.382768] pci 0000:00:18.0: [1022:1200] type 00 class 0x060000
[ 0.382814] pci 0000:00:18.1: [1022:1201] type 00 class 0x060000
[ 0.382855] pci 0000:00:18.2: [1022:1202] type 00 class 0x060000
[ 0.382896] pci 0000:00:18.3: [1022:1203] type 00 class 0x060000
[ 0.382942] pci 0000:00:18.4: [1022:1204] type 00 class 0x060000
[ 0.383017] pci 0000:01:05.0: [1002:9616] type 00 class 0x030000
[ 0.383023] pci 0000:01:05.0: reg 0x10: [mem 0xd0000000-0xdfffffff pref]
[ 0.383027] pci 0000:01:05.0: reg 0x14: [io 0xd000-0xd0ff]
[ 0.383030] pci 0000:01:05.0: reg 0x18: [mem 0xfeaf0000-0xfeafffff]
[ 0.383038] pci 0000:01:05.0: reg 0x24: [mem 0xfe900000-0xfe9fffff]
[ 0.383053] pci 0000:01:05.0: supports D1 D2
[ 0.383073] pci 0000:01:05.1: [1002:960f] type 00 class 0x040300
[ 0.383079] pci 0000:01:05.1: reg 0x10: [mem 0xfeae8000-0xfeaebfff]
[ 0.383105] pci 0000:01:05.1: supports D1 D2
[ 0.383149] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.383151] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.383153] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.383156] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.383196] pci 0000:02:00.0: [1b21:1142] type 00 class 0x0c0330
[ 0.383211] pci 0000:02:00.0: reg 0x10: [mem 0xfebf0000-0xfebf7fff 64bit]
[ 0.383291] pci 0000:02:00.0: PME# supported from D3cold
[ 0.387833] pci 0000:00:07.0: PCI bridge to [bus 02]
[ 0.387838] pci 0000:00:07.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.387897] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.387909] pci 0000:03:00.0: reg 0x10: [io 0xe800-0xe8ff]
[ 0.387928] pci 0000:03:00.0: reg 0x18: [mem 0xfdfff000-0xfdffffff 64bit pref]
[ 0.387940] pci 0000:03:00.0: reg 0x20: [mem 0xfdff8000-0xfdffbfff 64bit pref]
[ 0.387991] pci 0000:03:00.0: supports D1 D2
[ 0.387992] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.388015] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.395838] pci 0000:00:0a.0: PCI bridge to [bus 03]
[ 0.395842] pci 0000:00:0a.0: bridge window [io 0xe000-0xefff]
[ 0.395845] pci 0000:00:0a.0: bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[ 0.395916] pci 0000:00:14.4: PCI bridge to [bus 04] (subtractive decode)
[ 0.395924] pci 0000:00:14.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.395925] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.395927] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.395928] pci 0000:00:14.4: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
[ 0.395929] pci 0000:00:14.4: bridge window [mem 0xcff00000-0xdfffffff] (subtractive decode)
[ 0.395931] pci 0000:00:14.4: bridge window [mem 0xf0000000-0xfebfffff] (subtractive decode)
[ 0.411908] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 7 *10 12 14 15)
[ 0.411940] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 7 10 *11 12 14 15)
[ 0.411970] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 7 10 *11 12 14 15)
[ 0.411998] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 7 *10 11 12 14 15)
[ 0.412027] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 7 10 11 12 14 15) *0, disabled.
[ 0.412056] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 7 10 11 12 14 15) *0, disabled.
[ 0.412084] ACPI: PCI Interrupt Link [LNKG] (IRQs *11)
[ 0.412111] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 7 10 11 12 14 15) *0, disabled.
[ 0.412239] ACPI: Enabled 1 GPEs in block 00 to 1F
[ 0.412244] ACPI: _SB
.PCI0: notify handler is installed
[ 0.412270] Found 1 acpi root devices
[ 0.412355] vgaarb: setting as boot device: PCI:0000:01:05.0
[ 0.412356] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.412358] vgaarb: loaded
[ 0.412358] vgaarb: bridge control possible 0000:01:05.0
[ 0.412484] SCSI subsystem initialized
[ 0.412543] libata version 3.00 loaded.
[ 0.412558] ACPI: bus type USB registered
[ 0.412570] usbcore: registered new interface driver usbfs
[ 0.412576] usbcore: registered new interface driver hub
[ 0.412599] usbcore: registered new device driver usb
[ 0.412700] PCI: Using ACPI for IRQ routing
[ 0.420775] PCI: pci_cache_line_size set to 64 bytes
[ 0.420822] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.420824] e820: reserve RAM buffer [mem 0xcfe80000-0xcfffffff]
[ 0.420886] NetLabel: Initializing
[ 0.420887] NetLabel: domain hash size = 128
[ 0.420888] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.420897] NetLabel: unlabeled traffic allowed by default
[ 0.420948] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.420951] hpet0: 4 comparators, 32-bit 14.318180 MHz counter
[ 0.423010] Switched to clocksource hpet
[ 0.426868] AppArmor: AppArmor Filesystem Enabled
[ 0.426889] pnp: PnP ACPI init
[ 0.426899] ACPI: bus type PNP registered
[ 0.427007] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.427046] pnp 00:01: [dma 4]
[ 0.427060] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.427088] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.427102] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.427121] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.427496] pnp 00:05: [dma 0 disabled]
[ 0.427623] pnp 00:05: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.427659] pnp 00:06: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.427932] pnp 00:07: [dma 0 disabled]
[ 0.427982] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.428047] system 00:08: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.428049] system 00:08: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.428050] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.428201] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.428203] system 00:09: [io 0x040b] has been reserved
[ 0.428205] system 00:09: [io 0x04d6] has been reserved
[ 0.428206] system 00:09: [io 0x0c00-0x0c01] has been reserved
[ 0.428208] system 00:09: [io 0x0c14] has been reserved
[ 0.428209] system 00:09: [io 0x0c50-0x0c51] has been reserved
[ 0.428210] system 00:09: [io 0x0c52] has been reserved
[ 0.428212] system 00:09: [io 0x0c6c] has been reserved
[ 0.428213] system 00:09: [io 0x0c6f] has been reserved
[ 0.428215] system 00:09: [io 0x0cd0-0x0cd1] has been reserved
[ 0.428216] system 00:09: [io 0x0cd2-0x0cd3] has been reserved
[ 0.428218] system 00:09: [io 0x0cd4-0x0cd5] has been reserved
[ 0.428219] system 00:09: [io 0x0cd6-0x0cd7] has been reserved
[ 0.428220] system 00:09: [io 0x0cd8-0x0cdf] has been reserved
[ 0.428222] system 00:09: [io 0x0b00-0x0b3f] has been reserved
[ 0.428223] system 00:09: [io 0x0800-0x089f] could not be reserved
[ 0.428225] system 00:09: [io 0x0b00-0x0b0f] has been reserved
[ 0.428226] system 00:09: [io 0x0b20-0x0b3f] has been reserved
[ 0.428228] system 00:09: [io 0x0900-0x090f] has been reserved
[ 0.428229] system 00:09: [io 0x0910-0x091f] has been reserved
[ 0.428231] system 00:09: [io 0xfe00-0xfefe] has been reserved
[ 0.428233] system 00:09: [mem 0xcff00000-0xcfffffff] has been reserved
[ 0.428234] system 00:09: [mem 0xffb80000-0xffbfffff] has been reserved
[ 0.428236] system 00:09: [mem 0xfec10000-0xfec1001f] has been reserved
[ 0.428238] system 00:09: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.428239] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.428352] system 00:0a: [io 0x0230-0x023f] has been reserved
[ 0.428354] system 00:0a: [io 0x0290-0x029f] has been reserved
[ 0.428355] system 00:0a: [io 0x0300-0x030f] has been reserved
[ 0.428357] system 00:0a: [io 0x0a30-0x0a3f] has been reserved
[/spoiler]
Part #2
[spoiler][ 0.428358] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.428396] system 00:0b: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.428398] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.443177] system 00:0c: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.443179] system 00:0c: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.443181] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.443183] system 00:0c: [mem 0x00100000-0xcfefffff] could not be reserved
[ 0.443184] system 00:0c: [mem 0xfec00000-0xffffffff] could not be reserved
[ 0.443186] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.443255] pnp: PnP ACPI: found 13 devices
[ 0.443256] ACPI: bus type PNP unregistered
[ 0.449381] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.449384] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.449387] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.449389] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.449392] pci 0000:00:07.0: PCI bridge to [bus 02]
[ 0.449394] pci 0000:00:07.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.449397] pci 0000:00:0a.0: PCI bridge to [bus 03]
[ 0.449398] pci 0000:00:0a.0: bridge window [io 0xe000-0xefff]
[ 0.449401] pci 0000:00:0a.0: bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[ 0.449404] pci 0000:00:14.4: PCI bridge to [bus 04]
[ 0.449414] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.449416] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.449417] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.449418] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.449419] pci_bus 0000:00: resource 8 [mem 0xcff00000-0xdfffffff]
[ 0.449421] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfebfffff]
[ 0.449422] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.449423] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfeafffff]
[ 0.449425] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.449426] pci_bus 0000:02: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.449428] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 0.449429] pci_bus 0000:03: resource 2 [mem 0xfdf00000-0xfdffffff 64bit pref]
[ 0.449431] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 0.449432] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 0.449433] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.449434] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.449436] pci_bus 0000:04: resource 8 [mem 0xcff00000-0xdfffffff]
[ 0.449437] pci_bus 0000:04: resource 9 [mem 0xf0000000-0xfebfffff]
[ 0.449462] NET: Registered protocol family 2
[ 0.449647] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.449868] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.450212] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.450262] TCP: reno registered
[ 0.450272] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.450327] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.450433] NET: Registered protocol family 1
[ 0.450442] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[ 0.991447] pci 0000:01:05.0: Video device with shadowed ROM
[ 0.991554] PCI: CLS 64 bytes, default 64
[ 0.991605] Trying to unpack rootfs image as initramfs…
[ 1.339318] Freeing initrd memory: 26512K (ffff880034c28000 - ffff88003660c000)
[ 1.339580] PCI-DMA: Disabling AGP.
[ 1.339677] PCI-DMA: aperture base @ c4000000 size 65536 KB
[ 1.339678] PCI-DMA: using GART IOMMU.
[ 1.339680] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[ 1.343214] LVT offset 1 assigned for vector 0x400
[ 1.343223] IBS: LVT offset 1 assigned
[ 1.343246] perf: AMD IBS detected (0x0000001f)
[ 1.343282] microcode: CPU0: patch_level=0x010000c8
[ 1.343289] microcode: CPU1: patch_level=0x010000c8
[ 1.343300] microcode: CPU2: patch_level=0x010000c8
[ 1.343309] microcode: CPU3: patch_level=0x010000c8
[ 1.343369] microcode: Microcode Update Driver: v2.00 [email protected], Peter Oruba
[ 1.343370] Scanning for low memory corruption every 60 seconds
[ 1.343572] Initialise system trusted keyring
[ 1.343612] audit: initializing netlink socket (disabled)
[ 1.343621] type=2000 audit(1421066478.232:1): initialized
[ 1.365084] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.366128] zbud: loaded
[ 1.366244] VFS: Disk quotas dquot_6.5.2
[ 1.366278] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.366652] fuse init (API version 7.22)
[ 1.366707] msgmni has been set to 15457
[ 1.366749] Key type big_key registered
[ 1.367176] Key type asymmetric registered
[ 1.367178] Asymmetric key parser ‘x509’ registered
[ 1.367198] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.367235] io scheduler noop registered
[ 1.367236] io scheduler deadline registered (default)
[ 1.367253] io scheduler cfq registered
[ 1.367331] pcieport 0000:00:07.0: irq 40 for MSI/MSI-X
[ 1.367465] pcieport 0000:00:0a.0: irq 41 for MSI/MSI-X
[ 1.367503] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.367512] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.367545] ipmi message handler version 39.2
[ 1.367611] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 1.367614] ACPI: Power Button [PWRB]
[ 1.367636] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.367637] ACPI: Power Button [PWRF]
[ 1.368433] GHES: HEST is not enabled!
[ 1.368517] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.388973] 00:07: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.390086] Linux agpgart interface v0.103
[ 1.391065] brd: module loaded
[ 1.391609] loop: module loaded
[ 1.391872] libphy: Fixed MDIO Bus: probed
[ 1.391928] tun: Universal TUN/TAP device driver, 1.6
[ 1.391929] tun: (C) 1999-2004 Max Krasnyansky [email protected]
[ 1.391960] PPP generic driver version 2.4.2
[ 1.391988] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.391991] ehci-pci: EHCI PCI platform driver
[ 1.392095] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 1.392100] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.392103] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.392113] ehci-pci 0000:00:12.2: debug port 1
[ 1.392150] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe8ff800
[ 1.403616] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.403662] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.403664] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.403665] usb usb1: Product: EHCI Host Controller
[ 1.403666] usb usb1: Manufacturer: Linux 3.13.0-43-generic ehci_hcd
[ 1.403667] usb usb1: SerialNumber: 0000:00:12.2
[ 1.403751] hub 1-0:1.0: USB hub found
[ 1.403756] hub 1-0:1.0: 6 ports detected
[ 1.403933] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 1.403937] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 1.403940] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.403950] ehci-pci 0000:00:13.2: debug port 1
[ 1.403984] ehci-pci 0000:00:13.2: irq 19, io mem 0xfe8ff400
[ 1.415614] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.415648] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.415650] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.415651] usb usb2: Product: EHCI Host Controller
[ 1.415652] usb usb2: Manufacturer: Linux 3.13.0-43-generic ehci_hcd
[ 1.415653] usb usb2: SerialNumber: 0000:00:13.2
[ 1.415737] hub 2-0:1.0: USB hub found
[ 1.415741] hub 2-0:1.0: 6 ports detected
[ 1.415831] ehci-platform: EHCI generic platform driver
[ 1.415837] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.415838] ohci-pci: OHCI PCI platform driver
[ 1.415924] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 1.415927] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 3
[ 1.415946] ohci-pci 0000:00:12.0: irq 16, io mem 0xfe8fe000
[ 1.475656] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.475658] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.475660] usb usb3: Product: OHCI PCI host controller
[ 1.475661] usb usb3: Manufacturer: Linux 3.13.0-43-generic ohci_hcd
[ 1.475662] usb usb3: SerialNumber: 0000:00:12.0
[ 1.475756] hub 3-0:1.0: USB hub found
[ 1.475762] hub 3-0:1.0: 3 ports detected
[ 1.475896] ohci-pci 0000:00:12.1: OHCI PCI host controller
[ 1.475899] ohci-pci 0000:00:12.1: new USB bus registered, assigned bus number 4
[ 1.475911] ohci-pci 0000:00:12.1: irq 16, io mem 0xfe8fd000
[ 1.535693] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.535695] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.535696] usb usb4: Product: OHCI PCI host controller
[ 1.535698] usb usb4: Manufacturer: Linux 3.13.0-43-generic ohci_hcd
[ 1.535699] usb usb4: SerialNumber: 0000:00:12.1
[ 1.535791] hub 4-0:1.0: USB hub found
[ 1.535797] hub 4-0:1.0: 3 ports detected
[ 1.535931] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 1.535934] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 1.535954] ohci-pci 0000:00:13.0: irq 18, io mem 0xfe8fc000
[ 1.595720] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.595722] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.595724] usb usb5: Product: OHCI PCI host controller
[ 1.595725] usb usb5: Manufacturer: Linux 3.13.0-43-generic ohci_hcd
[ 1.595726] usb usb5: SerialNumber: 0000:00:13.0
[ 1.595818] hub 5-0:1.0: USB hub found
[ 1.595824] hub 5-0:1.0: 3 ports detected
[ 1.595956] ohci-pci 0000:00:13.1: OHCI PCI host controller
[ 1.595960] ohci-pci 0000:00:13.1: new USB bus registered, assigned bus number 6
[ 1.595973] ohci-pci 0000:00:13.1: irq 18, io mem 0xfe8fb000
[ 1.655755] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.655758] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.655759] usb usb6: Product: OHCI PCI host controller
[ 1.655760] usb usb6: Manufacturer: Linux 3.13.0-43-generic ohci_hcd
[ 1.655761] usb usb6: SerialNumber: 0000:00:13.1
[ 1.655852] hub 6-0:1.0: USB hub found
[ 1.655859] hub 6-0:1.0: 3 ports detected
[ 1.655994] ohci-pci 0000:00:14.5: OHCI PCI host controller
[ 1.655997] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 7
[ 1.656008] ohci-pci 0000:00:14.5: irq 18, io mem 0xfe8fa000
[ 1.715793] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.715795] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.715796] usb usb7: Product: OHCI PCI host controller
[ 1.715797] usb usb7: Manufacturer: Linux 3.13.0-43-generic ohci_hcd
[ 1.715798] usb usb7: SerialNumber: 0000:00:14.5
[ 1.715894] hub 7-0:1.0: USB hub found
[ 1.715900] hub 7-0:1.0: 2 ports detected
[ 1.715950] ohci-platform: OHCI generic platform driver
[ 1.715955] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.716008] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.716013] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 8
[ 1.776418] xhci_hcd 0000:02:00.0: irq 42 for MSI/MSI-X
[ 1.776425] xhci_hcd 0000:02:00.0: irq 43 for MSI/MSI-X
[ 1.776430] xhci_hcd 0000:02:00.0: irq 44 for MSI/MSI-X
[ 1.776434] xhci_hcd 0000:02:00.0: irq 45 for MSI/MSI-X
[ 1.776439] xhci_hcd 0000:02:00.0: irq 46 for MSI/MSI-X
[ 1.776517] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.776519] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.776520] usb usb8: Product: xHCI Host Controller
[ 1.776521] usb usb8: Manufacturer: Linux 3.13.0-43-generic xhci_hcd
[ 1.776522] usb usb8: SerialNumber: 0000:02:00.0
[ 1.776617] hub 8-0:1.0: USB hub found
[ 1.776623] hub 8-0:1.0: 2 ports detected
[ 1.776677] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.776680] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 9
[ 1.776728] usb usb9: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.776730] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.776731] usb usb9: Product: xHCI Host Controller
[ 1.776732] usb usb9: Manufacturer: Linux 3.13.0-43-generic xhci_hcd
[ 1.776733] usb usb9: SerialNumber: 0000:02:00.0
[ 1.776796] hub 9-0:1.0: USB hub found
[ 1.776801] hub 9-0:1.0: 2 ports detected
[ 1.783897] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.784273] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.784279] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.784390] mousedev: PS/2 mouse device common for all mice
[ 1.784502] rtc_cmos 00:02: RTC can wake from S4
[ 1.784596] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.784620] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.784670] device-mapper: uevent: version 1.0.3
[ 1.784717] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: [email protected]
[ 1.784723] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.784795] TCP: cubic registered
[ 1.784860] NET: Registered protocol family 10
[ 1.784996] NET: Registered protocol family 17
[ 1.785004] Key type dns_resolver registered
[ 1.785176] Loading compiled-in X.509 certificates
[ 1.785987] Loaded X.509 cert ‘Magrathea: Glacier signing key: 55ab2fe28ed5c60df9587150d1734c920ea7b818’
[ 1.785994] registered taskstats version 1
[ 1.787947] Key type trusted registered
[ 1.789258] Key type encrypted registered
[ 1.790567] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.790570] IMA: No TPM chip found, activating TPM-bypass!
[ 1.790762] regulator-dummy: disabling
[ 1.790814] Magic number: 15:274:683
[ 1.790905] rtc_cmos 00:02: setting system clock to 2015-01-12 12:41:19 UTC (1421066479)
[ 1.790993] acpi-cpufreq: overriding BIOS provided _PSD data
[ 1.791362] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.791363] EDD information not available.
[ 1.791380] PM: Hibernation image not present or could not be loaded.
[ 1.792621] Freeing unused kernel memory: 1336K (ffffffff81d20000 - ffffffff81e6e000)
[ 1.792623] Write protecting the kernel read-only data: 12288k
[ 1.794449] Freeing unused kernel memory: 796K (ffff880001739000 - ffff880001800000)
[ 1.795958] Freeing unused kernel memory: 688K (ffff880001b54000 - ffff880001c00000)
[ 1.806235] systemd-udevd[123]: starting version 204
[ 1.821094] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.821102] ahci 0000:00:11.0: version 3.0
[ 1.821109] r8169 0000:03:00.0: can’t disable ASPM; OS doesn’t have ASPM control
[ 1.821457] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 1.821460] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 1.821810] r8169 0000:03:00.0: irq 47 for MSI/MSI-X
[ 1.822086] scsi0 : ahci
[ 1.822403] [drm] Initialized drm 1.1.0 20060810
[ 1.823037] r8169 0000:03:00.0 eth0: RTL8168f/8111f at 0xffffc90000c7c000, 78:24:af:35:97:e7, XID 08000800 IRQ 47
[ 1.823039] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.823150] scsi1 : ahci
[ 1.823225] scsi2 : ahci
[ 1.826252] scsi3 : ahci
[ 1.826292] ata1: SATA max UDMA/133 abar m1024@0xfe8ffc00 port 0xfe8ffd00 irq 22
[ 1.826294] ata2: SATA max UDMA/133 abar m1024@0xfe8ffc00 port 0xfe8ffd80 irq 22
[ 1.826296] ata3: SATA max UDMA/133 abar m1024@0xfe8ffc00 port 0xfe8ffe00 irq 22
[ 1.826299] ata4: SATA max UDMA/133 abar m1024@0xfe8ffc00 port 0xfe8ffe80 irq 22
[ 1.840377] scsi4 : pata_atiixp
[ 1.840496] scsi5 : pata_atiixp
[ 1.840561] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 1.840563] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 1.844568] [drm] radeon kernel modesetting enabled.
[ 1.844790] [drm] initializing kernel modesetting (RS780 0x1002:0x9616 0x1043:0x8388).
[ 1.844802] [drm] register mmio base: 0xFEAF0000
[ 1.844803] [drm] register mmio size: 65536
[ 1.845351] ATOM BIOS: B27732
[ 1.845369] radeon 0000:01:05.0: VRAM: 256M 0x00000000C0000000 - 0x00000000CFFFFFFF (256M used)
[ 1.845371] radeon 0000:01:05.0: GTT: 512M 0x00000000A0000000 - 0x00000000BFFFFFFF
[ 1.845374] [drm] Detected VRAM RAM=256M, BAR=256M
[ 1.845375] [drm] RAM width 32bits DDR
[ 1.845447] [TTM] Zone kernel: Available graphics memory: 3958618 kiB
[ 1.845448] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 1.845449] [TTM] Initializing pool allocator
[ 1.845452] [TTM] Initializing DMA pool allocator
[ 1.845467] [drm] radeon: 256M of VRAM memory ready
[ 1.845468] [drm] radeon: 512M of GTT memory ready.
[ 1.845473] [drm] Loading RS780 Microcode
[ 1.845518] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 1.869058] [drm] PCIE GART of 512M enabled (table at 0x00000000C0040000).
[ 1.869106] radeon 0000:01:05.0: WB enabled
[ 1.869108] radeon 0000:01:05.0: fence driver on ring 0 use gpu addr 0x00000000a0000c00 and cpu addr 0xffff88020ec87c00
[ 1.869109] radeon 0000:01:05.0: fence driver on ring 3 use gpu addr 0x00000000a0000c0c and cpu addr 0xffff88020ec87c0c
[ 1.869111] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.869112] [drm] Driver supports precise vblank timestamp query.
[ 1.869124] [drm] radeon: irq initialized.
[ 1.901011] [drm] ring test on 0 succeeded in 1 usecs
[ 1.901017] [drm] ring test on 3 succeeded in 2 usecs
[ 1.901082] [drm] Enabling audio 0 support
[ 1.901097] [drm] ib test on ring 0 succeeded in 0 usecs
[ 1.901123] [drm] ib test on ring 3 succeeded in 0 usecs
[ 1.901278] [drm] Radeon Display Connectors
[ 1.901279] [drm] Connector 0:
[ 1.901280] [drm] VGA-1
[ 1.901281] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 1.901282] [drm] Encoders:
[ 1.901283] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 1.901283] [drm] Connector 1:
[ 1.901284] [drm] HDMI-A-1
[ 1.901285] [drm] HPD3
[ 1.901286] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
[ 1.901286] [drm] Encoders:
[ 1.901287] [drm] DFP3: INTERNAL_KLDSCP_LVTMA
[ 1.901306] [drm] radeon: power management initialized
[ 1.979963] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 2.004922] [drm] fb mappable at 0xD0141000
[ 2.004924] [drm] vram apper at 0xD0000000
[ 2.004924] [drm] size 8294400
[ 2.004925] [drm] fb depth is 24
[ 2.004926] [drm] pitch is 7680
[ 2.004993] fbcon: radeondrmfb (fb0) is primary device
[ 2.012462] ata6.00: ATA-8: Hitachi HDS5C3020ALA632, ML6OA5C0, max UDMA/133
[ 2.012464] ata6.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.012469] ata6.01: ATAPI: ATAPI iHAS122 E, 2L04, max UDMA/100
[ 2.028457] ata6.00: configured for UDMA/100
[ 2.044343] ata6.01: configured for UDMA/100
[ 2.051150] Console: switching to colour frame buffer device 128x48
[ 2.057983] radeon 0000:01:05.0: fb0: radeondrmfb frame buffer device
[ 2.057985] radeon 0000:01:05.0: registered panic notifier
[ 2.057989] [drm] Initialized radeon 2.36.0 20080528 for 0000:01:05.0 on minor 0
[ 2.112919] usb 2-1: New USB device found, idVendor=03f0, idProduct=c611
[ 2.112922] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.112924] usb 2-1: Product: Officejet 4630 series
[ 2.112925] usb 2-1: Manufacturer: HP
[ 2.112926] usb 2-1: SerialNumber: CN4B15900505Y0
[ 2.140057] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.224111] usb 2-3: new high-speed USB device number 3 using ehci-pci
[ 2.320171] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.320197] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.320221] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.321464] ata1.00: ATA-8: ST500DM002-1BD142, KC45, max UDMA/133
[ 2.321466] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.322410] ata3.00: ATA-7: Maxtor 6V250F0, VA111630, max UDMA/133
[ 2.322412] ata3.00: 490234752 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.322967] ata1.00: configured for UDMA/133
[ 2.323124] scsi 0:0:0:0: Direct-Access ATA ST500DM002-1BD14 KC45 PQ: 0 ANSI: 5
[ 2.323251] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.323263] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.323266] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.323359] sd 0:0:0:0: [sda] Write Protect is off
[ 2.323361] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.323403] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.325591] ata3.00: configured for UDMA/133
[ 2.325709] scsi 2:0:0:0: Direct-Access ATA Maxtor 6V250F0 VA11 PQ: 0 ANSI: 5
[ 2.325814] sd 2:0:0:0: [sdb] 490234752 512-byte logical blocks: (251 GB/233 GiB)
[ 2.325836] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 2.325905] sd 2:0:0:0: [sdb] Write Protect is off
[ 2.325908] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.325941] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.340165] tsc: Refined TSC clocksource calibration: 3415.335 MHz
[ 2.346696] sdb: sdb1
[ 2.346979] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.350634] ata4.00: ATA-7: MAXTOR STM3250820AS, 3.AAE, max UDMA/133
[ 2.350636] ata4.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.383222] sda: sda1 sda2 sda3 < sda5 sda6 >
[ 2.383629] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.408976] ata4.00: configured for UDMA/133
[ 2.409102] scsi 3:0:0:0: Direct-Access ATA MAXTOR STM325082 3.AA PQ: 0 ANSI: 5
[ 2.409219] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 2.409220] sd 3:0:0:0: [sdc] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 2.409305] sd 3:0:0:0: [sdc] Write Protect is off
[ 2.409307] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.409346] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.409370] scsi 5:0:0:0: Direct-Access ATA Hitachi HDS5C302 ML6O PQ: 0 ANSI: 5
[ 2.409484] sd 5:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 2.409524] sd 5:0:0:0: Attached scsi generic sg3 type 0
[ 2.409545] sd 5:0:0:0: [sdd] Write Protect is off
[ 2.409547] sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 2.409584] sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.412584] scsi 5:0:1:0: CD-ROM ATAPI iHAS122 E 2L04 PQ: 0 ANSI: 5
[ 2.415642] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.415645] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.415732] sr 5:0:1:0: Attached scsi CD-ROM sr0
[ 2.415821] sr 5:0:1:0: Attached scsi generic sg4 type 5
[ 2.425582] sdd: sdd1
[ 2.428391] sd 5:0:0:0: [sdd] Attached SCSI disk
[ 2.448693] sdc: sdc1
[ 2.448955] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 2.711121] random: nonblocking pool is initialized
[ 2.915768] usb 2-3: New USB device found, idVendor=0bda, idProduct=0151
[ 2.915771] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.915772] usb 2-3: Product: USB2.0-CRW
[ 2.915774] usb 2-3: Manufacturer: Generic
[ 2.915775] usb 2-3: SerialNumber: 20060413092100000
[ 2.919436] usb-storage 2-3:1.0: USB Mass Storage device detected
[ 2.919512] scsi6 : usb-storage 2-3:1.0
[ 2.919559] usbcore: registered new interface driver usb-storage
[ 3.236719] usb 4-3: new full-speed USB device number 2 using ohci-pci
[ 3.343551] Switched to clocksource tsc
[ 3.409749] usb 4-3: New USB device found, idVendor=046d, idProduct=c52e
[ 3.409752] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.409753] usb 4-3: Product: USB Receiver
[ 3.409754] usb 4-3: Manufacturer: Logitech
[ 3.416425] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.426032] usbcore: registered new interface driver usbhid
[ 3.426035] usbhid: USB HID core driver
[ 3.426254] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[ 3.426258] EXT4-fs (sda1): write access will be enabled during recovery
[ 3.427437] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:12.1/usb4/4-3/4-3:1.0/input/input5
[ 3.427515] hid-generic 0003:046D:C52E.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:12.1-3/input0
[ 3.427805] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:12.1/usb4/4-3/4-3:1.1/input/input6
[ 3.428431] hid-generic 0003:046D:C52E.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:12.1-3/input1
[ 3.508459] EXT4-fs (sda1): recovery complete
[ 3.520349] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.805016] usb 6-1: new low-speed USB device number 2 using ohci-pci
[ 3.923446] scsi 6:0:0:0: Direct-Access Generic- Compact Flash 1.00 PQ: 0 ANSI: 0 CCS
[ 3.929695] scsi 6:0:0:1: Direct-Access Generic- SM/xD-Picture 1.00 PQ: 0 ANSI: 0 CCS
[ 3.935947] scsi 6:0:0:2: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 0 CCS
[ 3.942206] scsi 6:0:0:3: Direct-Access Generic- MS/MS-Pro 1.00 PQ: 0 ANSI: 0 CCS
[ 3.942382] sd 6:0:0:0: Attached scsi generic sg5 type 0
[ 3.942465] sd 6:0:0:1: Attached scsi generic sg6 type 0
[ 3.942539] sd 6:0:0:2: Attached scsi generic sg7 type 0
[ 3.942614] sd 6:0:0:3: Attached scsi generic sg8 type 0
[ 3.949073] sd 6:0:0:0: [sde] Attached SCSI removable disk
[ 3.949824] sd 6:0:0:1: [sdf] Attached SCSI removable disk
[ 3.950574] sd 6:0:0:2: [sdg] Attached SCSI removable disk
[ 3.951320] sd 6:0:0:3: [sdh] Attached SCSI removable disk
[ 3.982082] usb 6-1: New USB device found, idVendor=1a2c, idProduct=0c21
[ 3.982085] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.982087] usb 6-1: Product: USB Keyboard
[ 3.982088] usb 6-1: Manufacturer: USB
[ 3.989311] input: USB USB Keyboard as /devices/pci0000:00/0000:00:13.1/usb6/6-1/6-1:1.0/input/input7
[ 3.989378] hid-generic 0003:1A2C:0C21.0003: input,hidraw2: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-0000:00:13.1-1/input0
[ 3.996392] input: USB USB Keyboard as /devices/pci0000:00/0000:00:13.1/usb6/6-1/6-1:1.1/input/input8
[ 3.996468] hid-generic 0003:1A2C:0C21.0004: input,hidraw3: USB HID v1.10 Mouse [USB USB Keyboard] on usb-0000:00:13.1-1/input1
[ 4.105533] usb 9-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 4.122944] usb 9-1: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 4.125693] usb 9-1: New USB device found, idVendor=0480, idProduct=d010
[ 4.125695] usb 9-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.125697] usb 9-1: Product: External USB 3.0
[ 4.125698] usb 9-1: Manufacturer: Toshiba
[ 4.125699] usb 9-1: SerialNumber: 20130126037325
[ 4.127976] usb-storage 9-1:1.0: USB Mass Storage device detected
[ 4.128046] scsi7 : usb-storage 9-1:1.0
[ 4.237682] usb 9-2: new SuperSpeed USB device number 3 using xhci_hcd
[ 4.255280] usb 9-2: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 4.258018] usb 9-2: New USB device found, idVendor=0480, idProduct=d010
[ 4.258020] usb 9-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.258022] usb 9-2: Product: External USB 3.0
[ 4.258023] usb 9-2: Manufacturer: Toshiba
[ 4.258024] usb 9-2: SerialNumber: 20121127005198
[ 4.259603] usb-storage 9-2:1.0: USB Mass Storage device detected
[ 4.259672] scsi8 : usb-storage 9-2:1.0
[ 5.128270] scsi 7:0:0:0: Direct-Access Toshiba External USB 3.0 0201 PQ: 0 ANSI: 6
[ 5.128440] sd 7:0:0:0: Attached scsi generic sg9 type 0
[ 5.129909] sd 7:0:0:0: [sdi] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 5.130101] sd 7:0:0:0: [sdi] Write Protect is off
[ 5.130103] sd 7:0:0:0: [sdi] Mode Sense: 2b 00 00 00
[ 5.130294] sd 7:0:0:0: [sdi] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.131851] sd 7:0:0:0: [sdi] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 5.153613] sdi: sdi1
[ 5.156559] sd 7:0:0:0: [sdi] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 5.156953] sd 7:0:0:0: [sdi] Attached SCSI disk
[ 5.258572] scsi 8:0:0:0: Direct-Access Toshiba External USB 3.0 0201 PQ: 0 ANSI: 6
[ 5.258703] sd 8:0:0:0: Attached scsi generic sg10 type 0
[ 5.258871] sd 8:0:0:0: [sdj] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 5.259044] sd 8:0:0:0: [sdj] Write Protect is off
[ 5.259046] sd 8:0:0:0: [sdj] Mode Sense: 2f 00 00 00
[ 5.259222] sd 8:0:0:0: [sdj] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.259466] sd 8:0:0:0: [sdj] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 5.286578] sdj: sdj1
[ 5.286947] sd 8:0:0:0: [sdj] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 5.287300] sd 8:0:0:0: [sdj] Attached SCSI disk
[ 14.713789] Adding 8388604k swap on /dev/sda2. Priority:-1 extents:1 across:8388604k FS
[ 14.764109] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.813670] systemd-udevd[348]: starting version 204
[ 14.896194] lp: driver loaded but no devices found
[ 14.900941] ppdev: user-space parallel port driver
[ 14.904435] parport_pc 00:05: reported by Plug and Play ACPI
[ 14.904490] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 14.904741] wmi: Mapper loaded
[ 14.914333] ATK0110 ATK0110:00: Overriding interface detection
[ 14.930077] ACPI Warning: 0x0000000000000b00-0x0000000000000b07 SystemIO conflicts with Region \SOR1 1 (20131115/utaddress-251)
[ 14.930084] ACPI Warning: 0x0000000000000b00-0x0000000000000b07 SystemIO conflicts with Region \SMRG 2 (20131115/utaddress-251)
[ 14.930087] ACPI Warning: 0x0000000000000b00-0x0000000000000b07 SystemIO conflicts with Region _SB_.PCI0.SBRG.ASOC.SMRG 3 (20131115/utaddress-251)
[ 14.930091] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 14.932064] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[ 14.932135] sp5100_tco: PCI Revision ID: 0x3c
[ 14.932153] sp5100_tco: failed to find MMIO address, giving up.
[ 14.938450] MCE: In-kernel MCE decoding enabled.
[ 14.940210] EDAC MC: Ver: 3.0.0
[ 14.942501] WARNING! power/level is deprecated; use power/control instead
[ 14.944742] AMD64 EDAC driver v3.4.0
[ 14.944770] EDAC amd64: DRAM ECC disabled.
[ 14.944775] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 14.944775] Either enable ECC checking or force module loading by setting ‘ecc_enable_override’.
[ 14.944775] (Note that use of the override may cause unknown side effects.)
[ 14.948694] usblp 2-1:1.1: usblp1: USB Bidirectional printer dev 2 if 1 alt 0 proto 2 vid 0x03F0 pid 0xC611
[ 14.949168] usblp 2-1:1.2: usblp2: USB Bidirectional printer dev 2 if 2 alt 0 proto 2 vid 0x03F0 pid 0xC611
[ 14.949189] usbcore: registered new interface driver usblp
[ 14.963658] systemd-udevd[385]: renamed network interface eth0 to eth1
[ 14.970542] hda-intel 0000:00:14.2: Using LPIB position fix
[ 14.973921] hda-intel 0000:00:14.2: Enable sync_write for stable communication
[ 14.982576] autoconfig: line_outs=4 (0x1c/0x19/0x22/0x23/0x0) type:line
[ 14.982578] speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 14.982580] hp_outs=1 (0x1d/0x0/0x0/0x0/0x0)
[ 14.982581] mono: mono_out=0x0
[ 14.982581] dig-out=0x20/0x21
[ 14.982582] inputs:
[ 14.982584] Rear Mic=0x1a
[ 14.982585] Front Mic=0x1e
[ 14.982585] Line=0x1b
[ 14.991706] lp0: using parport0 (interrupt-driven).
[ 14.992877] input: HDA ATI SB Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input16
[ 14.994141] input: HDA ATI SB Line Out Side as /devices/pci0000:00/0000:00:14.2/sound/card0/input15
[ 14.995039] input: HDA ATI SB Line Out CLFE as /devices/pci0000:00/0000:00:14.2/sound/card0/input14
[ 14.995519] input: HDA ATI SB Line Out Surround as /devices/pci0000:00/0000:00:14.2/sound/card0/input13
[ 14.995597] input: HDA ATI SB Line Out Front as /devices/pci0000:00/0000:00:14.2/sound/card0/input12
[ 14.995642] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input11
[ 14.995683] input: HDA ATI SB Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input10
[ 14.995728] input: HDA ATI SB Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input9
[ 14.995937] hda-intel 0000:01:05.1: Using LPIB position fix
[ 14.998255] hda-intel 0000:01:05.1: Enable sync_write for stable communication
[ 15.002105] kvm: disabled by bios
[ 15.231044] type=1400 audit(1421066492.926:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/sbin/dhclient” pid=546 comm=“apparmor_parser”
[ 15.231053] type=1400 audit(1421066492.926:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/NetworkManager/nm-dhcp-client.action” pid=546 comm=“apparmor_parser”
[ 15.231056] type=1400 audit(1421066492.926:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/connman/scripts/dhclient-script” pid=546 comm=“apparmor_parser”
[ 15.231069] type=1400 audit(1421066492.926:5): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/sbin/dhclient” pid=545 comm=“apparmor_parser”
[ 15.231078] type=1400 audit(1421066492.926:6): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/NetworkManager/nm-dhcp-client.action” pid=545 comm=“apparmor_parser”
[ 15.231081] type=1400 audit(1421066492.926:7): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/connman/scripts/dhclient-script” pid=545 comm=“apparmor_parser”
[ 15.231423] type=1400 audit(1421066492.926:8): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/NetworkManager/nm-dhcp-client.action” pid=546 comm=“apparmor_parser”
[ 15.231429] type=1400 audit(1421066492.926:9): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/connman/scripts/dhclient-script” pid=546 comm=“apparmor_parser”
[ 15.231447] type=1400 audit(1421066492.926:10): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/NetworkManager/nm-dhcp-client.action” pid=545 comm=“apparmor_parser”
[ 15.231450] type=1400 audit(1421066492.926:11): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/connman/scripts/dhclient-script” pid=545 comm=“apparmor_parser”
[ 15.251659] HDMI ATI/AMD: no speaker allocation for ELD
[ 15.251736] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:05.1/sound/card1/input17
[ 15.251990] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 17.314203] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 18.789377] EXT4-fs (sdc1): recovery complete
[ 18.789383] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 18.808465] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 18.848335] EXT4-fs (sdd1): recovery complete
[ 18.848341] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
[ 18.896626] EXT4-fs (sda6): recovery complete
[ 18.896631] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 18.952743] init: failsafe main process (744) killed by TERM signal
[ 19.064000] Bluetooth: Core ver 2.17
[ 19.064021] NET: Registered protocol family 31
[ 19.064022] Bluetooth: HCI device and connection manager initialized
[ 19.064033] Bluetooth: HCI socket layer initialized
[ 19.064035] Bluetooth: L2CAP socket layer initialized
[ 19.064039] Bluetooth: SCO socket layer initialized
[ 19.066497] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.066500] Bluetooth: BNEP filters: protocol multicast
[ 19.066506] Bluetooth: BNEP socket layer initialized
[ 19.067231] Bluetooth: RFCOMM TTY layer initialized
[ 19.067238] Bluetooth: RFCOMM socket layer initialized
[ 19.067242] Bluetooth: RFCOMM ver 1.11
[ 19.134456] init: cups main process (869) killed by HUP signal
[ 19.134464] init: cups main process ended, respawning[/spoiler]
Your dmesg has no indication of your TV card. Is this a USB or PCI device?
If it is USB then try:
lsusb
If it is a PCI (internal) then try:
lspci -v
lspci -v
[spoiler]00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] RS780 Host Bridge
Subsystem: ASUSTeK Computer Inc. Device 8388
Flags: bus master, 66MHz, medium devsel, latency 0
Capabilities:
00:01.0 PCI bridge: ASUSTeK Computer Inc. AMD RS780/RS880 PCI to PCI bridge (int gfx) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fe900000-feafffff
Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
Capabilities:
00:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 3) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: feb00000-febfffff
Capabilities:
Kernel driver in use: pcieport
00:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Prefetchable memory behind bridge: 00000000fdf00000-00000000fdffffff
Capabilities:
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [IDE mode] (prog-if 01 [AHCI 1.0])
Subsystem: ASUSTeK Computer Inc. M4A785TD Motherboard
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 22
I/O ports at c000 [size=8]
I/O ports at b000 [size=4]
I/O ports at a000 [size=8]
I/O ports at 9000 [size=4]
I/O ports at 8000 [size=16]
Memory at fe8ffc00 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Subsystem: ASUSTeK Computer Inc. Device 8389
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
Memory at fe8fe000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci-pci
00:12.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0 USB OHCI1 Controller (prog-if 10 [OHCI])
Memory at fe8fd000 (32-bit, non-prefetchable) [size=4K]
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 17
Memory at fe8ff800 (32-bit, non-prefetchable) [size=256]
Capabilities:
Kernel driver in use: ehci-pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 18
Memory at fe8fc000 (32-bit, non-prefetchable) [size=4K]
00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0 USB OHCI1 Controller (prog-if 10 [OHCI])
Memory at fe8fb000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
Memory at fe8ff400 (32-bit, non-prefetchable) [size=256]
Capabilities:
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 3c)
Flags: 66MHz, medium devsel
Capabilities:
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 IDE Controller (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at ff00 [size=16]
Capabilities:
Kernel driver in use: pata_atiixp
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
Flags: bus master, slow devsel, latency 64, IRQ 16
Memory at fe8f4000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=64
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller (prog-if 10 [OHCI])
Memory at fe8fa000 (32-bit, non-prefetchable) [size=4K]
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor HyperTransport Configuration
Flags: fast devsel
Capabilities:
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Miscellaneous Control
Flags: fast devsel
Capabilities:
Kernel driver in use: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Link Control
Flags: fast devsel
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS780L [Radeon 3000] (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at d0000000 (32-bit, prefetchable) [size=256M]
I/O ports at d000 [size=256]
Memory at feaf0000 (32-bit, non-prefetchable) [size=64K]
Memory at fe900000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at [disabled]
Capabilities:
Kernel driver in use: radeon
01:05.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RS780 HDMI Audio [Radeon (HD) 3000 Series]
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at feae8000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
02:00.0 USB controller: ASMedia Technology Inc. Device 1142 (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device 85bf
Memory at febf0000 (64-bit, non-prefetchable) [size=32K]
Capabilities:
Kernel driver in use: xhci_hcd
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 09)
Subsystem: ASUSTeK Computer Inc. P8H77-I Motherboard
Flags: bus master, fast devsel, latency 0, IRQ 47
I/O ports at e800 [size=256]
Memory at fdfff000 (64-bit, prefetchable) [size=4K]
Memory at fdff8000 (64-bit, prefetchable) [size=16K]
Capabilities:
Kernel driver in use: r8169[/spoiler]
Nothing there either. Are you sure it is installed? Or it might just need re-seating.
Yep, it’s on OK, come to think of it, my other board didn’t ‘see’ it either!
